xj's gonna get a makeover
  • So Armand and I went and got my front yesterday, 95 f350 ball joint high pinion 60.
    And I just got off the phone for my new rear.
    D70, 5.38's, Detroit, dutchman alloys, discs, etc.
    Should be an awesome combo, can't wait to pickup the rear especially since all I have to do is brackets and brake lines and its in.
    Dan.
    • Originally posted by ct67_72 View Post
      How much cheaper would it really be? Not a lot. Plus the same size u joint un the front. C clips in the rear. Not really all that much of an upgrade.
      I'm gonna do this once so I never regret my choice or have to upgrade again.
      Since I have to change rims too which means tires again, I'm basing everything off running a 40" tire.
      guess that makes sense too...lol ...build it one more time and thats it...
      didnt know your going to 40's...some body modification in store??
      looks so naked in your driveway with no tires...think you will have it ready for the show in Meriden or what?
      99 XJ on tons and 40s....
      • I"ll be over soon to see what you have going on over there
        • I doubt it will be ready. I might have axles under it but i doubt it will have tires.
          Dan.
          • Originally posted by kracker View Post
            Oh and yeah, especially since the rear axle is going back 3 inches there's gonna be a liiiiitle more trimming lol. And I refuse to go any higher so I'm sure a lot of metal is gonna go.
            I might get the 38's. Which should be plenty and keep a better effective gear ratio. I just don't like that the mtr's are 14" wide.
            Dan.
            • why not just keep the 37's? trucks still going to work badass...will the rims work on your new axles? or going to larger rims size as well....?
              will it still be driveable on street ya think?
              • Mini road trip to go get D70
                • Originally posted by netrachamp1853 View Post
                    Can't. 15's won't clear brakes. Otherwise I would run them for now.
                    Dan.
                    • Got some parts....
                      Front brackets came in from Ballistic
                      Went and picked up my new rear with Armand. D70, detroit, 5.13's discs. I was told it has dutchman shafts but the ends look like stock. Not sure, maybe someone could ID them or tell me if they make shafts with stock looking ends.
                      disc brackets. New rotors, just sat for a bit. Have new pads and calipers also.
                      matching front gear set.
                      Ruff stuff cover
                      Got it under the jeep just because
                      Dan.
                      • Now's when things start to get interesting...
                        • awesome man!
                          • Thanks guys. Gonna order the rear perches ASAP and get the rear finished up. Still debating on what to do though. Have to go back ~2-2.5" and I'm not sure on the ruff stuff 2+ kit anymore.
                            Dan.
                            • cant wait to see what this looks like up close....any luck with deciding on tires?
                              • Nope. Gonna get something used and then ill figure it out. Most likely the 38 mtr though, maybe even the 37. Because of the 38 width, but I don't have the time id like to take to fit a 40 at the moment.
                                Dan.
