Mikes Build
  • There are definetly companies that sell flanges that you can pull after wheeling. Just throw the cap back on and it's just like having manual hubs.
    • got a link evan ?
      • bumpin for some new plans
        getting a one ton rear end, maybe I can find the same dana 60-2 sam has so I can keep my width good... then im getting an OX or ARB locker.
        anyone guess why im putting a selectable in the rear of a jeep that doesnt see much road time anymore?
        • Comp?
          • semi rear dig????
            2013 F150 fx4 (Tow Pig/DD)
            • 5.0 with the 3.73 option
            2003 TJ Rubicon
            • 4.0/42rle/np241or
            • 5.13's
            • 33” BFG KO2s
            • yeah
              • Actually front dig is what i meant... but i think you got that...
                That shit is awesome. Matt from master-pull was doing that when we were in California at KOH. It would still be comp legal right??
                2003 TJ Rubicon
                • 4.0/42rle/np241or
                • 5.13's
                • 33” BFG KO2s
                • Originally posted by Mike View Post
                  I'm not sure how much Sam spent on his, but I do remember him saying they are extremely rare.
                  Someone correct me if I'm wrong, but I would think it would be much easier to just pick up a full float 60(which are cheap), shorten it to the right width and weld on new spindles. You might have to go with custom chromo shafts, but you aren't breaking a 35spl. shaft unless you're running close to 40" rubber.
                  P.S. Owen dropped a link in his build thread for those drive slugs.
                  • basically when you needed to turn really tight, you'd unlock the rear, apply brake the left or right brake in the rear ( cutting brakes) and you would pivot around that one rear tire. Yes comp legal.
                    • Are cutting brakes legal tho??? in class two I don't think they are.You just have gas it with the e brake on... i think... pretty sure. I will look into it because it was interesting when matt did it.
                      2003 TJ Rubicon
                      • 4.0/42rle/np241or
                      • 5.13's
                      • 33” BFG KO2s
                      • after talking to Justin about it, im pretty sure cutting brakes are legal....
                        I just need to clarify with someone on what this rule means
                        No independent wheel manipulation.
                        Also
                        NO disengaging of rear axles (no front dig/burn). Doing so will result in immediate disqualification.
                        I wouldnt be doing any burns or digs, I would still be sending power to both axles, just only 3 wheels and use the one rear wheel not getting power as a pivot point.
                        • blew a brake hose at rausch last month.. havent had time to fix it until today... it was a Rubicon express SS braided line... I guess it wasnt long enough because it stretched and fucked part of the line up..
                          Replacement: 20 dollar OEM dodge hose... fucking mint and way over kill. its super long.
                          • its like 30ish inches long
                            • No independent wheel manipulation means you cannot disengage a single wheel from the rest of the drive train. They must all be in functioning order from the beginning to the end of the course. I do not believe the use cutting brakes is allowed.
                              RM
                              • whoa
                                make sure that shit dont hit any moving parts
