The Renegade Rescue
  • Here's the work from friday night and saturday, got the body off and made a dolly for it, then used the plasma to cut EVERYTHING off the frame and some rusted areas to prep for next weekend, next wheekend i'll grind it smoth, and fix the holes
    • 1991 YJ, 1 tons, locked, lots o armor, stretched, cage
      • 2 brand new fox 4" bumps and cans from a guy that works at liquid iron industries who decided not to use them, so i saved a couple bucks
        • Frame work
          • Just some pic from the day, wont work on it for the next few weeks because i'll be busy, only thing left to do on the frame is give it a good wire wheeling and that some god paint. Then i'll start working on the body, and make the body mounts once the body is done and mocked up on the frame rails
            • I threw out the old skid plate, and ordered the 2" drop one from Barnes4wd, just to easy for $120. The rails are clean and painted with the drivetrain just sitting on a strap for now. I'm going to cut off the extra plating JEEP put on the frame rails for the skid to mount to because it's bolt holes are pulled down some, and replace it with some 1/4 tube, in the same style with holes and nuts welded to the inside. Also got the body mostly apart, and started welding is some braces to keep the body straight when i cut the flood boards out.
              Here is how she sits now, but covered up outside while i'm not working on her.
              And a NCO im my platoon's little girl asked him to take pics everywhere he goes with "FLAT STANLEY" so though i would share it too.
              • if you dont want this to happen again maybe you should invest in some of this to start with..
                http://www.eastwood.com/internal-fra...ay-nozzle.html
                • Ordered barnes4WD 2" drop skid and winch/fairlead mount, and got them today!! very beefy!
                  • So go to the shop after school today, cut out the old factory frame sleeve for the stock skid, made up new sleeves, and got the new skid tacked to the sleeves to drill holes.
                    Tomorrow i'll weld nuts to the back and then bolt everything together and fully weld the new sleeves to the frame
                    BTW the Barnes4WD skids are super beef, it would prob cost more than it's price to buy the metal, cut it out and have it bent. Likin this company
                    • Lookin good.
                      Keep up the good work, I'm impressed......
                      Just don't go painting it all like a rainbow again
                      • It is staying black and green, but ONLY black and green. When i finish the body, i'm going to bring it to where i work and shoot good 2 part black and green on the body, and line-x the bottom, inside, and firewall
                        • This past friday finished the skid mount, fully welded the nuts on the inside of the frame so they will never spin, got everything in place and burned it together. Didnt have a lot of time because i need to leave for a friends house that night. Went to Punkin Chunkin the next day but failed to take any pictures.
                          This one was done upside down, on the bottom side of the frame rail
                          She's a smoker... i'm tryin to get her to kick it
                          Over the whole frame and everything i've done, i've just thrown on shity rustoleum until it's done and i can put 2 part on her
                          • So last Wednesday and Thursday i finally braced the body and cut the floors out
                            Add some braces to the door because there was a little bit of bending going on
                            • M.O.R.E. motor mounts ordered and will be here tomorrow....... engine will be on them friday
