the front is lower too. i didn't want to buy new leaf springs because of the $$ so the local spring shop reformed my leafsprings and took 4" of lift out of them, so there just a little longer than stock but stock height spring over now
The Renegade Rescue
Looking much improved!Shane "The Bag" Carlson
My "Bucket" Build
MilitaryJeepers.com
‚——P--;===±--= <-
!‚–’¯ƒ¹¶
so i've been bored with waiting between duty days and have been working on the jeep buttoning up loose ends. Patched rear left corner of frame.(had been putting it off because it didn;t look to bad but when i did it there was very little frame left after cutting out the rust) i've also started to fix my floors because apparently herculiner SUCKS. when i first bought my jeep i stripped the inside ground it down painted and herculined. back then there were 2 small spots of rust, now i'm replacing my whole passenger side floor for the most part. Also grant was over today helping me with the floors and we decided to cut my rockers out and boat side my shit and remount my sliders at a 45 degree angle. will have pic's of everything in the next couple days.1991 YJ, 1 tons, locked, lots o armor, stretched, cage
here are some pics from figuring out shock lengths, driving over some car and the new boatsides(they aren't super extreme boatsides but are still sweet, didn't do more cutting for boatsides due to i would have to redo the cage mounts if it did)
looks good man, think i saw you driving down federal rd the other day, you getting much harassment from the cops being comp cut?85 K10, 44front,ff14 rear, 350,th350,Np208, 39.5/13.5r20 IROKs. almost done
New toy 88 yj, 4.2, 5speed,231. Its getting a soa, 78 f350 dana 60s, SYE, and some 37s.
Originally posted by CumminsJeep View Postneeds moar flecks. looks good
and i fixed those tail lights(bad fuse, good thing the cop that pulled me over is a good family friend)
so i was thinking with the new way the rockers were mounted the joints would be a big issue in rocks and if i were to get hung up on one i would be screwed so i notched out all 3 joints and put a tube in, functional, and i think it looks bad ass
if you compare it to the last pic in the last set of pics you can see hoe the joint would have been a hang up spot1991 YJ, 1 tons, locked, lots o armor, stretched, cage
