Originally posted by raze1287
Ideal Setup
Originally posted by Capt. Crunch View Postyea i know the whole rear axle game, Ive done alot of research in that area. i guess i was looking for more opinions on the front.
I'm Planning on going to 35's after the rear swap
Is it worth swapping the D30 with the 2.5L still in it?
i donno much about the WJ setup on a d30 but i would do that for brakes and steering"when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
Originally posted by Capt. Crunch View Postalso, no rear swap??
you dont need long arms if you dont have lots of lift. just swap out coils, or find someone to trade.
also a curry antirock is a sweet setup"when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
Mr. english major... wouldn't it be more proper to say "He is also bigger than you..." rather than " He also is bigger than you..."
Just sayin.
Last edited by SupermanIce-J; 03-30-2010, 03:45 PM.2013 F150 fx4 (Tow Pig/DD)- 5.0 with the 3.73 option
- 5.13's
- 33” BFG KO2s
i have the same exact tj as you. in a realistic perfect world first thing i'd do is swap an ax15 for the ax5. it will blow up. i've gone through 4. then i'd swap a rear 44. disc swap. gear it to 5.13. run 35's and lunchboxs front and rear.2 tj's
Originally posted by Arundlemcbrundle View Posti have the same exact tj as you. in a realistic perfect world first thing i'd do is swap an ax15 for the ax5. it will blow up. i've gone through 4. then i'd swap a rear 44. disc swap. gear it to 5.13. run 35's and lunchboxs front and rear.4x4 Station Wagon...
Originally posted by grundlepunch View Postdo you have stock control arms now?
if you do i would highly recommend adjustable short arms with flex joints, they make a good amount of difference and the arms are way stronger4x4 Station Wagon...
