Ideal Setup
    What do you want it for trail riding, commuting, snow, mud bogging, competing?
    You need to figure out where you want to go with the rig before we start suggesting what to build next. They are all different setups, some cross over but it is better to have a plan on what you want, tire size and the difficulty of trails you want to accomplish.
    Safety and keep your rig from breaking is the most important.
    If it was me I would add a locker and compete in RCrocs class 1.
    I enjoy the competition that class is not expensive to be competitive, you can make a 33" rig very capable.
      yea i know the whole rear axle game, Ive done alot of research in that area. i guess i was looking for more opinions on the front.
      I'm Planning on going to 35's after the rear swap
      Is it worth swapping the D30 with the 2.5L still in it?
      4x4 Station Wagon...
        Originally posted by raze1287 View Post
        8.8
        Benefits:
        Larger ring gear
        Thicker tubes
        31 spline
        Availability
        Disc brakes
        Disadvantages:
        c-clip
        Less ground clearance
        Not exactly Jeep width 1.5" narrower iirc
        Not bolt in, so you better learn to weld and get good at it
        D44
        Benefits:
        Bolt in available if you have a TJ
        More ground clearance
        Larger aftermarket support
        Disadvantages:
        Drum brakes
        30 spline
        8.5"? ring gear
        Smaller tubes
        More expensive if you are getting one from a TJ
        just to elaborate
        8.8= spinnyriffic tubes (not a big deal)
        swiss cheese carrier
        tubes neck down at the housing ends
        44=33 and 35 spline upgrades
          i wouldnt
            well im going to school in VT next year, I will be bring the jeep with me. So that means it will be making a 6.5 hr drive every once in a while. I would like to have a rig that can take what ever i throw at it.
            I like the exploration scene more then the crawling and far more then the mudding scene
              stock 44>stock 8.8
              mild 44> mild 8.8
              built to fuck and back 8.8>built to fuck and back 44
              i like the 8.8 over the 44, stock vs stock i would say they are about equal. Built you are correct the 8.8 will out do the 44 any day. Availability on both are about the same. If i could make it cheap to convert and 8.8 to 6x5.5 i would sell my 44 rear in a heart beat
                j
                please elaborate some more.. haha
                  the tubes that spin on the 8.8 can be solved by welding them to the 3rd member. Carriers not a huge deal. As for the neck down i have never seen any issues with them at all. They run them all day in 600hp mustangs and such with no issues
                  in stock form i would not trust my 44 on anything bigger than 35" tires. Where as i know someone with a stock 31 spline 8.8 on 38" tires spooled with no issues
                    custom alloy shafts yo
                    and monte carlo/eldorado calipers using chevy truck rotors
                      i know someone who doesnt run lockers because they add to much weight for sand wheeling
                        not cheap ive looked into it. i got all the stuff for the 6x5.5 disk brake conversion minus the bracket
                          oh yea dude that extra 9oz of unsprung weight makes a huge difference on sand
                            350 for a pair for 33 and 35 spline stuff from moser with 10 year warranty on 35 spline shit
                            im sure 31 spline is the same/cheaper
                              ask jeepforum
                              shit is the truth
                                are they the goofy ass ones with the million holes for different lug patterns? i may look into it farther down the road all depends on what i can sell the 44 for
                                ask jeepforum
                                shit is the truth
                                im soooo happy i forgot all my login info there
                                also you are supposed to sipe your tires when locking it for sand
