Ideal Setup
  • #46
    seems like an opinion thread on axle choice.
    I chose the 8.8 due to availability, disc brakes, and 4.10. also i think its more beef than a 44. but thats for a cherokee.
    for you, a 44 will be easier to swap (if you find one out of a TJ) and you are running 33s so I dont think strength is the issue here. I think it depends on how much work you want to do.
    I agree with what RJ said. but I think its only 3/4" difference in length?????
    In my opinion, go with a TJ 44 and gear to 4.88, add some skids, and wheel it. Just for ease of install.
    • #47
      alright, seems like i got alot more research then I thought.
      4x4 Station Wagon...
      • #48
        and since a a tech post... why do you want HP over LP front and what are the benefits?
        • #49
          Originally posted by Burton58 View Post
          Tjs are low pinion d30 and can go as low as 5.38 gears iirc.
          5.89
          mo driveshaft clearance
          mo ring and pinion strength (on paper, never seen any real evidence)
          • #50
            thanks sam
            • #51
              I'm not sure what would be best with the 4 banger but 5.13s are also available for that. Though a lp30 is said to be weaker because the gears ride on the coast side I believe? Correct me if I'm wrong
              • #52
                I has 2.5l TJ, 4" lift, 33s, 8.8 w/ aussie, WON TON, bumpas f+r
                Soon to come:
                Rockers, gas tank skid (in the mail)
                HPd30 with 4.88s
                Also debating on trussing the d30, debating whether to stay open up front or not
                • #53
                  never seen any concrete evidence either
                  • #54
                    What are peoples opinions on trussing a hp30? Worth it? Pros/Cons?
                    • #55
                      It wont smile
                      • #56
                        i personally wouldnt go over 4.88 in a d30, the pinion is so damn small at that size i wouldnt want it any smaller.
                        • #57
                          I would say the 8.8 is the way to go over a D44... you could seriously wheel it without issue...
                          If you want it to be absolutely rediculous just drop in a super 88 kit in... chromoly axle shafts and no clips. Then you will have more than a D60 IMO and disk brakes
                          http://www.chucksirois.com/jeep
                          • #58
                            More than a D-60? Are you fawking kidding me with this comment? Are you seriously stating a 8.8 w/super 88 kit is more beef then a Dana 60?
                            HOONIGAN FOR LIFE
                            OLD 4X4'S NEVER DIE!!!!!
                            • #59
                              maybe not more, but that's a decent setup.
                              • #60
                                haha if i do the swap, im not gonna be able to put in a super anything
