Ideal Setup
  • #61
    They actually make 5.38s for Dana 30s? Last I bought gears for a d30 which was two years ago or more they only made up to 4.88. I can't imagine that pinion getting any smaller without just turning to dust.
    Oh and Dana 44 > 8.8
    • #62
      low pinion
      • #63
        edit : nvm. found 5.38's for a d30.
        in that case, junkyard open 8.8 with discs. gear to 5.38's front and rear and a lunchbox in the back on 35's. dats mah plan
        • #64
          Just because i've been thinking about it, If i was budget minded and wanted a good performing "bolt on" jeep (meaning i didnt want to fab my own suspension ect.)
          motor / gaurds:
          1" mml
          flat belly skid
          gas tank skid
          rocker gaurds
          trim da fendas
          axles:
          d30 front
          d44 rear w/ bracket kit (mover rear shocks up)
          4.88 gears
          lunchbox lockers
          suspension / steering:
          max 3" lift prob 2~2.5
          SYE w/ driveshaft
          adjustable control arms w/ flex joints
          adjustable track bars with flex joints
          1:ton over the knuckle steering
          antirock if you can swing the loot
          all on 33" KM2's
          you would have a kick ass little jeep that would be capable as all hell , i personally wouldn't do 35's
          • #65
            thanks man i appreciate the help and suggestions
            4x4 Station Wagon...
            • #66
              ok now i might be asking too much from you, but from the build plan you mentioned, what would be the order you would go in, because obviously a first year college student could do all that at once
              • #67
                skids & steering first... so your shit wont break and get beat up first
                then gears and lockers... so you can do cool shit
                then new control arms ect.... so you can perform better
                • #68
                  Thanks Dana, now I want a TJ.
                  • #69
                    dana is the sis tj wheeling spokesman
                    • #70
                      sell 2 xj's and buy a TJ
                      • #71
                        sweet man thanks
                        • #72
                          Originally posted by Hydra View Post
                          He also is bigger than you....
                          thats makes no difference to me... swizel tits
                          • #73
                            motor / gaurds:
                            1" mml
                            flat belly skid
                            gas tank skid
                            rocker gaurds
                            trim da fendas
                            axles:
                            d30 front
                            4.88 gears
                            lunchbox lockers
                            SYE w/ driveshaft
                            all on 33" KM2's
                            I'm almost thur Not quite the same setup but close, soon enough
                            • #74
                              Originally posted by CaptainInsano View Post
                              More than a D-60? Are you fawking kidding me with this comment? Are you seriously stating a 8.8 w/super 88 kit is more beef then a Dana 60?
                              90% of FF D60's come with 30 spline shafts, and a super 8.8 kit can use up to a 33 spline chromoly shaft.
                              Now, hardly anyone runs the stock D60 stuff, but I'm just sayin
                              • #75
                                I once met a girl named Juicebox, boy did she have a thing or two to say about Italian cooking...
