Ideal Setup
  • Ideal Setup
    alright so i wanna start planning some bigger projects for the summer. One being rear axle swap. I was hoping to get your guys opinion on what you would do with out an engine swap. Like front/ axles, tires size. etc.
    Current Setup:
    2.5L 97 TJ
    4 in SA lift
    33 BFG's
    Discos
    stock armor
    go..
    4x4 Station Wagon...
    What do you not like about it now????
    I would say wonton steering, scrap the D35 for a d44 or 8.8 and gear it... and wheel the piss outta it.
    2013 F150 fx4 (Tow Pig/DD)
    • 5.0 with the 3.73 option
    2003 TJ Rubicon
    • 4.0/42rle/np241or
    • 5.13's
    • 33” BFG KO2s
      what gears you plannin on having?
        mo gears
        less lift
        bellyup skid
          and a better rear like an 8.8
            what about dana 60 vs. 8.8 vs. 44? the 44 i have heard is semi weak, the 8.8 very strong, but how good is the dana 60? better than 8.8 im assuming, but what size ring gear, shafts does it have etc....
              Well with a dana 30 front i dont think a 60 would be smart. also with 33" tires a dana 60 would be stupid due to ground clearance issues
                if you are on 33's and dont want to go bigger than a 35
                dana44 /thread
                especially with the 4 popper
                  well my thought was to put a 8.8 or 44 in the rear and regear to 4.88's. and keep the 30, beefy steering.
                    8.8>44
                      60? I think you're being slightly overworried.
                      A 44 or 8.8 would be plentystrong
                      Thatsaid, armor, and gears/lockers
                        big enough ring gear. 16 to 46 spline shafts
                          Good thoughts Mr. Crunch!
                          2003 TJ Rubicon
                          • 4.0/42rle/np241or
                          • 5.13's
                          • 33” BFG KO2s
                            Benefits:
                            Larger ring gear
                            Thicker tubes
                            31 spline
                            Availability
                            Disc brakes
                            Disadvantages:
                            c-clip
                            Less ground clearance
                            Not exactly Jeep width 1.5" narrower iirc
                            Not bolt in, so you better learn to weld and get good at it
                            D44
                            Benefits:
                            Bolt in available if you have a TJ if its from a tj
                            More ground clearance
                            Larger aftermarket support
                            Disadvantages:
                            Drum brakes
                            30 spline
                            8.5"? ring gear
                            Smaller tubes
                            More expensive if you are getting one from a TJ
                              Originally posted by raze1287 View Post
                              8.8>44
                              stock 44>stock 8.8
                              mild 44> mild 8.8
                              built to fuck and back 8.8>built to fuck and back 44
