Operation: BACK IN BLACK! 97 xj build
  • Originally posted by CumminsJeep View Post
    maybe do the semi gloss black and paint the bolts blue?
    this.....
    95XJ tons 3 link 36s 5:38s
    97 F-250HD 7.3 Turbo Diesel
    "Shut up and Wheel"
      do eet.
      • that is way too much work for the likes of me lol
        • ktm orange
          • I kinda like the idea of the whole thing being blue... it would be different.
            2013 F150 fx4 (Tow Pig/DD)
            • 5.0 with the 3.73 option
            2003 TJ Rubicon
            • 4.0/42rle/np241or
            • 5.13's
            • 33” BFG KO2s
            • back when i did my wheels it was either orange or blue
              but orange would make it look like a creamsicle on my white jeep
              this one will look like a jack-0-lantern when orange methinks
              • TAPS TAPS TAPS TAPS TAPS EVEERRYYBODDEEEE
                • I think the Orange would look sweet with the black. Im going to do charcol or gunmetal accents with my DD.
                  • the 240k mile injun is gawn
                    i has 130k mile injun now
                    it has moar balls
                    2 psi moar oil pressure (still sucks)
                    less leaks
                    and no more bottom end noise
                    gonna give it a compression test and see if its worth puttin an oil pump in
                    if the compression sucks im gonna run some 15-40 in the bitch
                    • sweet. how long did that take?
                      • what is the oil pressure?
                        • sam, are you getting the oil pressure based on the dash gauge? I had a problem with my 97 reading low on the dash, so I changed the oil pressure sending unit, still was low, so I hooked up a mechanical gauge and it just was the actual dash gauged broken, the mechanical gauge rode about 20 psi higher.
                          • Originally posted by 93XJRay View Post
                            maybe 8-10 hours
                            the last engine with the mechanical guage read the same as the dash guage
                            low
                            ima put a real guage in this bitch before i figure anything out.
                            the jeep was fine for about 60 miles last night
                            then today i started getting what i can best describe as "torque converter chatter"
                            its a vibration/chattery noise coming from the bell housing and its getting worse.
                            happens at certain rpm's sitting, and under certain loads while driving (lugging the engine for the most part)
                            torque converter bolts are all tight.
                            i did swap in the converter from a 96 with 60k miles
                            the internets dont say anything about this being a common problem
                            so this could be fun
                            • hrmmm thats interesting. Well if you need a hand down there give me a call; I'll take a ride down
                                i is doing this right meow
                                just installed the monte carlo rear calipers because im sick of the eldorado calipers and having a useless e-brake. all 4 35" km2's at 25 psi now lock right up on dry pavement at 70 mph with minimal brake pedal input. it' stops like any normal car, its amazing.
                                i need to get to the welding shop monday to fix mah welder, then i shall modify my tnt belly pan to my liking.
                                other things i might get around to before the comp (6 days)
                                bend trackbar so it dont hit mah dana44
                                bumpstops
                                eat a few cheeseburgers
                                rear recovery point (yea i kinda need that don't i?)
                                finish up the front crossmember
