Operation: BACK IN BLACK! 97 xj build
  • SWEET
    just upgraded from yukon super joints to spicer 5-760's
    full circle clips
    im staying on 35's with these bitches in there
    • Originally posted by Ktmracer419 View Post
      fuck yukon super joints
      less than a year old and they are shot
      With lockouts? Holy fuck.
      • Originally posted by Even View Post
        yep
        im done with yukon products
        i can see why one would be shot. one of the grease fittings was missing since the last time i greased em' (before i pulled em out of the white jeep)
        but its not like normal u joint wear where they flop side to side. its almost like the ears on the shafts were stretched, but they werent. and the u joint would go up and down in the caps.
        the o rings were also flattened
          yep
          So it sounds like the fact they don't use needle bearings wasn't even the issue?
          Any plans in the future to use a different set of dookin joints?
          • if anything im going all out and doin ctms
            but the 760s should be fine on 35" radials
            • Sam, could you be so kind as to explain the difference in the joints to me? The axles I got have yukon super joints too and if Im going to get spares down the road I would like to be edumacted
              • Originally posted by Saharicon View Post
                yukon super joints are supposed to be strong as balls
                but require high maintenance i suppose
                i would grease them after every wheeling run
                and you gotta use that special marine grade copper grease that yukon sells for an ungodly amount of money
                  ok, thanks man. You dont need some kind of special yukon grease gun do you? Any ole grease gun will do?
                    The superjoints use a specific grease gun that yukon sells IIRC.
                    • oh hey
                      • where they checking your jeep for ghosts?
                        • they were closed
                            oh hey
                            told you they would be there in the next few days! you gonna just spray paint them?
                            • Originally posted by CumminsJeep View Post
                              yea, gloss black prolly
                              i was thinkin the same color of the wheels
                              but thats a shitload of blue. i wants it more subtle blue accents somewhur
                                maybe do the semi gloss black and paint the bolts blue?
