Operation: BACK IN BLACK! 97 xj build
  • #91
    im not doing a subaru color
    when i had the subaru grill on my jeep all it did was break
    • #92
      you'll do a subaru color if i have to pour it on your roof myself
      • #93
        and ill drench your subaru in emerald pearl coat
        • #94
          paint it like my friends mustang
          • #95
            jcr 1/4 guards with integrated taillights are on thier way
            gonna use them as well as a rear bumper to mount a dookin-ass tire carrier eventually
            none of that sissy, clankin, bumper only mounted shit
            • #96
              4dr gaurds for a 2 door ftl
              • #97
                the armor has saved the rear quarter a few times, i like it just cause it acts like an insurance policy, i dont need to hammer out the rear if i hit a tree or something.
                .,=====o00o ______________
                //___l__,\____\,___ ____
                l_---\____l----[]lllllll[] _
                _(o)_)___(o)_)--o-)_)
                • #98
                  it was on sale for $210 and came with the taillights. and i can never get as sexy of a shape with 97+ taillights with my metal fabbing skills. I plan on plating to the front doors (welding some actually, seeing as one of my lower sections behind the door is beginning to rot out) I think I can tie it in pretty good if i can find someone willing to give some 3/16" a slight curve to it and I weld them together and grind em' smooth
                  • #99
                    thatd look good. get cracking on it.
                    • I built mahself a trackbar
                      i kept blowing through the bushings on the tnt trackbar and the superflex joint was shot. the trackbar bracket is still welded to my old jeep and im never cutting it off.
                      so I built diss
                      it uses 7/8" heims
                      misalignment spacers
                      9/16" bolts
                      tubing inserts plug welded and circumference
                      the tubing is 1.75x1/4" wall dom
                      each bracket is essentially 3/16" thick hitch tubing. the upper bracket uses a $8 piece of 1/4" plate from home depot which I didn't even have to cut.
                      I bent the trackbar using my good ol' harbor freight pipe bender.
                      tnt on top
                      ktm on bottom
                      • Looks sick. I woul dhave had so much more done to my XJ when i had it if i had my own welder.
                        • Looks good.
                          I actually already have almost the exact same shit to build my own, except make it 5/8" bolts and 1.5" DOM.
                          • (ha)dookin
                            • Originally posted by Even View Post
                              Looks good.
                              i was gonna run 5/8" bolts. but i lost a pair of misalignment spacers
                              then I figgured whatevs, i never broke 1/2" bolts, i'll be good with 9/16"
                              • Would using heims like that fit the stock width mounts?
                                I gotta build one and I can't figure out if a hiem will fit where thr axlesidevmount goes
