Reason I was going with the TNT y-link was because i havent heard any complaints from Will and others who use it, and for the fact of the belly skid built in.
Havent looked into BDS, clayton seems beefy as fuck but havent looked into that either.
Front bumper I like but really havent found anything else that really gets my attention. I dunno, maybe ill hold off on bumpers for now until I find something that can truly make me happy.
The truss is expensive, but it takes every single bit of guess work out of setting up the brackets, no measuring, getting angles and making sure shit lines up. ( i have no knowlege of setting up axle bracketry) Just set the bitch ontop of the axle and get the pinion angle and weld it on. Its also beefy as fuck
TNT has a inner steering brace you can get with the bumper
You could reuse the factory steering box spacer but, to prevent failure, you may want to replace it with a bullet-proof steel one for a small additional cost. Adding this brace can prevent that fateful unibody cracking/breakage that happens far too often as the factory cast aluminum one fails.
