I have been debating what to do with my upper link. It is too long and there isnt enough separation at the frame side. I want it on the frame and off the x-member like the lowers. I debated for a while and came across ruffstuffs 3 legged bracket. Being poor I decided to make something similar, because I think it will work.
Im going to plate the inside of the frame with angle iron, but up the frame and across the floor. Tied into the bottom stiffener. So this mount will be wended the angle up the frame and across the floor.
I have to clean it up a bit and round off the tab better but I think it will due.
Its 3x3 1/4" wall square tube with one side cut off. Then I cut 2, 3/8" thick tabs that fit inside. I welded one in and tacked the other, I need to put my mock up joint in to make sure the spacing is right.
Then I can weld it in and shorten the upper arm.
