Project "Pocket Change"
  • #61
    good work wade, glad to see it ready to rock
    Thanks dude unfortunatly I wont make the club comp gunna have it out the 16th for a shakedown run at RC. Got less then a month and alot to do! It will be done though
    • #62
      All good, hopefully you make some of the other stuff
      • #63
        Going to try to make OER again this year
        • #64
          Gears got done this past weekend while I was up in Oneonta having a good time. Now its time to do the brakes and get her running then shocks and drive shafts and ill be ready to rock
          • #65
            So this things running however it sounds like a cummins... Its getting no oil to the upper half of the motor, Im thinking the oil pump pickup sucked some of the sludge that i knocked loose up.. Im going to put some atf in it and run it through with hopes of clearing it out.. IF not i need a motor
            • #66
              that sucks goodthing is motors seem to be the cheap to obtain.
              • #67
                Yeah should be able to bet one for a few hundred bucks if not Ill buy a whole truck and part it out..
                • #68
                  Originally posted by WAD357 View Post
                  gunna have it out the 16th for a shakedown run at RC. thumbsup:
                  I CALL FUCKING BULLSHIT
                  • #69
                    It is bullshit now
                    • #70
                      Steering is now done, also have another motor lined up for this.. possibly going to work on the brakes after classs today
                      • #71
                        Everythings back together and lookin putryyy
                        Control arm angle at Ride height
                        Gettin there! got some side work to do this week so probably wont get much done but Next is brakes and shock mounts.. then I can drive it i think
                        • #72
                          mmmm nice. engines done?
                          • #73
                            I wish... still have to pull the new one out of the truck its in...
                            • #74
                              so you need shock mounts, brakes and an engine.... then you can drive it
                              • #75
                                This motor runsss Its gunna run until something comes out of it too
