Thanks dude unfortunatly I wont make the club comp gunna have it out the 16th for a shakedown run at RC. Got less then a month and alot to do! It will be done though
95XJ tons 3 link 36s 5:38s
97 F-250HD 7.3 Turbo Diesel
All good, hopefully you make some of the other stuff
Going to try to make OER again this year
Gears got done this past weekend while I was up in Oneonta having a good time. Now its time to do the brakes and get her running then shocks and drive shafts and ill be ready to rock
So this things running however it sounds like a cummins... Its getting no oil to the upper half of the motor, Im thinking the oil pump pickup sucked some of the sludge that i knocked loose up.. Im going to put some atf in it and run it through with hopes of clearing it out.. IF not i need a motor
Yeah should be able to bet one for a few hundred bucks if not Ill buy a whole truck and part it out..
Steering is now done, also have another motor lined up for this.. possibly going to work on the brakes after classs today
Gettin there! got some side work to do this week so probably wont get much done but Next is brakes and shock mounts.. then I can drive it i think
I wish... still have to pull the new one out of the truck its in...
This motor runsss Its gunna run until something comes out of it too
