Project: Back in the game 4 under $1k
  • #becauseJoeNitro
    • most like they were around the 9/9 area caleb
      • back in the game for under.......
        and joe replace those u joints soooooon. those arent gonna last much longer.
          • Originally posted by CumminsJeep View Post
            im getting those 297's from sam at M&G and i plan on rebuilding them with new wheel bearings and joints keepin the 260's for spares.
            #becauseJoeNitro
            • the bearings are brand new timkens with 1 year warrenty from autozone
              • Originally posted by Burton58 View Post
                oh... then ill just put the 297s on them...
                #becauseJoeNitro
                • do want....
                  http://www.nitro-gear.com/news/2009/...-u-joints.html
                  #becauseJoeNitro
                  • Originally posted by JoeNitro View Post
                    screw that 349 bucks for a set.....
                    ill just get a set off beaf spicers...
                    #becauseJoeNitro
                    • after a few weekends with the new axles/tires....
                      im beginning the process of properly bump stopping. Armand and I took a trip to harbor freight sunday and i purchased a flux core welder ... im working on a set of plates mounted off the u-bolt plate for the rear end to rais the bump stop contact point and adding longer bumps in the front. my next project will be to raise the rear shock mounts.
                      i just gotta practice welding first
                      pics will be up of the future shit i will most likely destroy/ruin/break
                      #becauseJoeNitro
                      • i took an extra set of u-bolt plates and welded 2 pices of anlge iron together to form a [] i then welded that to the u-bolt plate and bolted the plates to just the inner u-bolts on the axle so it overhung right under the rear bump stop, i added a support under the plate that sits on the axle tube so the plate will not bend, this created a raised contact point so my tires dont get smashed up into my fenders during flekx...
                        the creation
                        driver side at its contact point
                        passenger side at contact point
                        tire at full flex, no rubbing
                        then i used some plates and random metal i found in the scrap truck at work and built a little t-case skid just something to help protect it from being drug over rocks. its welded to the cross member and then off the back of the skid is a plate that is welded to the bottom and side of the unibody rail for added support...
                        sry shitty cell phone pics its all i had on me at the time...
                        #becauseJoeNitro
                          Am I misunderstanding you, or did you just say your crossmember is welded to the unibody?
                          • good job !
                            • Originally posted by Even View Post
                              the cross member itself is not welded to the unibody. the t-case skid i made is welded to the crossmember and off that i have a small maybe 2" wide pice of 3/16" welded to the body for supporting the back of the t-case skid...
                              so technically i guss you could say it is but..... why, is this bad?
                              #becauseJoeNitro
                              • How think is that skidplate?
