Originally posted by Even
My 1950 Willys Trail Rig
Wheeled it about 10-12 times now. Here a few pics and a summary of how it did and what I am going to do for next year.
The Good
- Stays cool
- 4 speed is fun to drive
- twin sticks are awesome
- 4 link works great
- beadlocks
The Bad
- Shocks not very effective in rear
- Front springs sag
- Transmission noisey
- Fuel injection needs to be tuned up
- Brakes could be better
- Starves for fuel on angles with less then 1/2 tank
- Gets hung up on skid plate sometimes
The Ugly
- Broke a rear transfer case output
- Broke a couple front driveshafts
- Broke a Milemarker Dana 60 hub
- Ignition switch shot
- Detroit locker is annoying on the road
Plans for 2010
- Ordered a new fuel cell, going to setup to sop fuel starvation
- Rebuild transmission
- Rebuild TBI and get it running right
- Install OBA system with air tank
- "New" tires- Michelin XML 325/85R16s
- Install boad stereo
- Fab new mounts for shocks in rear.
- Spare tire
- Rino line tub and finish the floor
- Modify the skid plate or build a new one so it is easier to change front driveshafts.
- Add a leaf to front springs (link it eventually)
- More
Modified Sanden Compressor "endless air"
New Tires- Gotta mount em on beadlocks and groove
Spare 13/38/16 Swamper TSL
New Fuel Cell RCI 2161A
Same as what I paid for my XLs 4 years ago, except I picked them up in west hartford, instead of paying 200 to ship from Cali. And they came on 8 lug rims!
Someone who uses this forum asked me if I liked the XLs last weekend and I never really thought about it til then... so of course I decided to try something new. Thanks pal1950 Willys Trail Rig
oh hell yeaP8R
I am about to order these. http://www.blackbirdscustomtrucks.co...x25.html#56d60
I figured it would be a good way to get it to stop better. My s10 always stopped great, it had a front hpd44 with chevy outers and 3/4 ton calipers. Right now I am not getting full lock up out of my front brakes, the calipers are huge ford dual piston, and the master is a 79 corvette. I do not think I am getting the pressure or volume that I need to get them to lock up the brakes. Not really applicable for me, but it is a great solution for someone looking to run a 15" wheel on a d60
Also ordered some inserts and jam nuts to make a trail spare upper link for the rearLast edited by OWEN; 01-23-2010, 08:43 AM.1950 Willys Trail Rig
Nice, I heard about them on Pirate, glad to know someone I know has had good luck with them!1950 Willys Trail Rig
It has gotten a good thrashing and not much lovin...
Now I have it back in the garage. My brake caliper mounts came in from Blackbird and the parts to fix my broken MM hub. The front axle is sitting on the bumpstops. I am going to start by pulling the front axle and rebuilding the front leaf packs and tearing down the axle to put on the new calipers/mounts. Also gotta order new greasable bolts for everything. Pics to follow1950 Willys Trail Rig
Saggy springs
Shocks with frame rash
$5 ea greasable bolts
Disassembled
Rebuilt sprindles
Blackbird brackets
Start... Good instructions
Put it togther and find I do not have enough room for the pads to fit
Face .1 " off rotor mounting face to bring rotor away from caliper bracket
Everything went smooth after that. Ditched the old 1/2" wheel studs for some new 9/16" ones so now all my lug nuts are the same
Went from 3 leafs to 5 and made new lower shock mounts. Drilled out greasable bolts and put in new zerks, and shortened them up so they don't hit rocks.
XMLs mounted on beadlocks
This thing gives me a boner every update..... I love itP8R
