time for new u-bolts
My 1950 Willys Trail Rig
Originally posted by TheDude View PostOwen if you need a hood, assuming that ding doesn't buff out, I believe I have 3 or 4 m38/cj2a hoods.
RM1950 Willys Trail Rig
Been a while since I have updated. I have just been beating this thing unmercifully, only problems have been locking hubs and I put a crack in my fuel cell. Still runs like shit and the transmission is getting noisier...hopefully it can make it til winter without needing an overhaul. I was able to fix the fuel cell with some aluminum welding rod I found at the hardware store. Yea I didn't think it would work, but it did! Not pretty but it works...
I was running drive flanges for a while but they are annoying to install/remove the slug for street driving. I am running some misc 30 spline hubs right now ($20 at the junk yard) but it picked up some 35 spline warns for an incredible price to throw on the shelf for the day I break a 30 spline outer
Also ordered Ballistic Fab's 14 bolt shave kit since they have 15% off
http://www.ballisticfabrication.com/...it_p_1728.html
I also want to put in CNC cutting brakes and maybe some suckdown winches... although I have been enjoying spending more time wheeling this then wrenching on it right now, although that will change I am sure.1950 Willys Trail Rig
Well the transmission was really noisey last time I bombed around in this turd. I am heading to PA to wheel for 4 days in a little less than 2 weeks so I figured I would drain the gear oil out and freshen it up with some Lucas... here is what I found
It never occured to me that the transmission is very suseptable to filling up with water as the rain can go right down the shift tower on top of the trans (no shifter boot). The goo was silvery and has the consistancy of a milk shake... not good, but no big chunks of metal. Hopefully some fresh gear oil will help quiet it down and get me through the rest of the season. I just don't have time to swap it and fit up my Chevy bellhousing.
I also ordered up some improvements for my hydro-assist steering including a new bigger and badder cooler, and oil temp guage which I am going to setup as a remote cooler with a 10" electric fan I have kicking around.1950 Willys Trail Rig
Gonna be down and out for a while, broke my transfer case in half on Jotters yesterday.Going to rebuild my drivetrain and sell it, and hopefully recover enough money to buy a StaK, which I want to mate to this SM420 I have kicking around.
Originally posted by CaptainInsano View PostOuch, how'd that happen?
It was an rough day, definately one to remember. At least I got a new yoke under warranty, too bad it wont do me any good right now!1950 Willys Trail Rig
Heres an update with some not-so-current upgrades and downgrades.
Before my lest trip to RC, I wanted to try to improve my crappy hydro-assist steering. I installed large bar and plate style style cooler in the rear of the jeep with a 10" 700cfm electric fan that runs whenever the key is on. I also bought a oil temp guage and sending unit, to keep an eye on it but I ran short on time and didn't get a change to put the guage in.
Start. I picked a spot that it would fit, and be safe from damage and built some brackets. It mounts to the inside of the driver side rear fenderwell.
The fan pushes air from the rear cargo area through the cooler. I cut the shroud out of some 16-or-so guage stainless
I swiss-cheesed the opposite side so the hot air flows outside of the jeep.
I bent up all the lines from 3/8" steel tubing. I ran them through the cab, attached to the roll cage. Pain in the ass
I still have a couple problems though, one of them is the stock pump is shot probably from years of abuse. I have to replace it, no getting around it. Also, the stock pump has a built in reservoir, which is lower than the cooler. When it engine is running all of the oil enters the system and then the res is low. With it still running, I can remove the cap and ad oil, but when I shut the engine off the excess pukes out of the breather, so I wind up not having enough oil, I think. In other words gravity causes the oil from the cooler to drain into the res. When I change the pump I am going to add an external reservior and mount it nice and high. Also, I am going to switch back to regular PS fluid. Right now I am running ATF and after a few beers one night had a brainstorm and realized the friction modifiers in the ATF probably aren't great for the power steering.
I also added this high tech boot to keep the rain out of my trans. It also keeps it all from running out everywhere when the jeep is on its side.
but when you do this, it doesn't really help
and some.... reasons to upgrade
I broke my 5th Milemarker hub right after getting through shoot the moon. I am going to package all of the broken parts up and send them back to Milemarker...meanwhile my stock $20 Ford OEM hubs have been holding up great.
I was running the comp area and broke my rear Wild Horses (made by Advance Adapters) 32 spline 1310 yoke in half... nice. They sent me a new one no questions asked. Heres one half... the other half is in my buddies Jeep. He was leaving the next morning so I swapped with him.
Which was great because then I was able to break my transfer case!
I am hoping to get my drivetrain all back together and sell it. I have a SM420 I want to run with a STak mini-monster.
Originally posted by SwampAss View PostI love seeing pics of your rig. It gives me ideas for my CJ2.
...Then I look at the CJ2.1950 Willys Trail Rig
