Well my Stak is still being built I guess but I want to have the transmission ready for when the transfer case arrives.
The transmisson is a SM420 from a 1950 GMC pickup. The only thing I am doing is changing the mainshaft and rear adapter housing to a Novak 23spline output dana 300 adapter.
I followed Novaks instructions for removing the main shaft, it was pretty easy.
Next I cleaned up the case with some simple green, wire wheeled it, and then cleaned with paint thinner
I have been liking this paint a lot lately and I had some kicking around
I bought the setup used, cheap. The previous owner had beat the shaft a little at the input end to remove it, which mushroomed it over a little. I spun it on the latthe at work, had to use sandpaper. The material of the shaft is very hard, it broke the cutter as soon as it touched!
I test fit the mainshaft with the input, and everything is all good now.
Next step is to swap everything over to the Novak main shaft and install... probably tomorrow.
