The Renegade Rescue
  • Originally posted by Jeepbonehead View Post
    because the way the steering box and steering is set up it to much of a hassle to do anything else, and i can do a good full hydro steering set-up for about $750
    THATS ALL!? SWEET DEAL
    • Still waiting for this jeep to get rescued.
      • you put together a strong full hydro system with a double rod cylinder, orbital valve, oil cooler, pump, lines, mounts, and rod ends
        • Why would I do that?
          • i heard full hydro is easy to just whip up
            how wont the stock steering work? trying to push the front axle forward? you can do an astro box that bolt in and gives you a forward facing pitman arm
            or you can get some crush sleeves and some metal and clock your steering box flat both are things i rather do then full hydro
            • Originally posted by grundlepunch View Post
              im intriguied
              do you have any more info on this?
              i have problems with my drag link end at the pitman arm hittin my tie rod on sweet jumps with 3" of lift and otk sturrin
              • Originally posted by Ktmracer419 View Post
                im intriguied
                im not sure where that would put you on an xj, but dudes that do it on yj/tj's do it for around 6" of stretch in the front
                • yj boxes are pretty much direct swaps on xj's
                  • Originally posted by fullwidthxj191 View Post
                    im talkin about where it will put the pitman arm in relation to everything else under an XJ, thanks though
                    • i wasn't sure if you were farmiliar with the unibody applications
                        i try not to be
                        • i did look into this but i want something stronger, and more reliable, with a hydro system everything is protected with the astro box in my aplication it sticks out to far forward
                          • lookin good man
                            • I see
                              I made a bracket to mount a hydro assist equipped wrangler box to my willys
                              Not to difficult or expensive, I like the idea that if the engine blows up or craps out it can still steer.
                              1950 Willys Trail Rig
                              • Originally posted by Buffalo Phil View Post
                                Seriously!
                                HOONIGAN FOR LIFE
                                OLD 4X4'S NEVER DIE!!!!!
