Project "Pocket Change"
  • #91
    Got some stuff done today, front kings are mounted perfectly front ds is shortened and got some other minor things done.
    To mount the shocks I used some tabs from Ruff Stuff and some stem eliminators from teraflex.
    The eliminators needed the powder coat wire wheeled off the bolt otherwise they were nice, shock tabs worked mint. I mounted the shocks so that at full droop the coil is off the bucket less that 1/2". The truck wil be limit strapped at some point so the coil doesnt leave the mount.
    Full droop
    Then I went on to shorten the front ds 3/4". First time doing this and it seems to have come out decent.
    I started by cutting a nice straight cut around the tube on the factory weld, then used the cut to run the grinder in and make it into a bigger grove.
    Then i switched back to a cut off and finished cutting the slip off.
    I removed 3/4" of material and then continued to set the slip back in place and burned it in
    Fresh coat of hammered grey and its lookin like new!
    As you can see in the last pic I also hooked up the filler neck and mounted the fuel tank, The trunk floor is not 100% so i just did this to get it safe to wheel at NAC Fest
    • #92
      dude this thing has come along nicely cant wait to see it at oer.
      Dizz dizz go sleep sleep
      • #93
        Thanks man, got a good amount done tonight its going to PA tommorow for a shake down run
        • #94
          Looking great WADE!
          2013 F150 fx4 (Tow Pig/DD)
          • 5.0 with the 3.73 option
          2003 TJ Rubicon
          • 4.0/42rle/np241or
          • 5.13's
          • 33” BFG KO2s
          • #95
            So this thing made it through a weekend of beating the ever living piss out of it... Had no working gauges but my guess was that it was running at 230 plus all weekend and it still runs great
            Ran some crazy stuff such as otters jotters trail 5 hill climb and all kinds of lines in devils den. Only issues I had were lack of rear shocks causing wheel hop and losing the exhaust so in my book for a hacked together jeep it wheeled great .
            Devils den
            Hill climb back behind jotters
            Otters
            Oh and i began modding the rockers for clearence similar to phil
            • #96
              boxed rocks next?..
              • #97
                yeah prob gunna boat side it
                • #98
                  Tommorow I plan to get some shit done. To start Im going to run a piece of 2x2x1/4 in between the rear wheel wells for my shocks to come up through the floor and mount to. Im also going to try to re seal the oil pan and maybe get some lights working.
                  • #99
                    Did some more work on this POS a friend of mine gave me a mint header panel with lights grill and bezels so i slapped that on looks so much better!
                    Also found the ground that wasnt connected which was causing me to have no gauges, hooked that up and theyre all working!
                    Also went and dropped the bent crossmember and fubared drive shaft.
                    • are you making your own crossmember? it's lookin good dude!
                      • Originally posted by clean4drxj View Post
                        yeah i think so going to make a very simple one from 2x6x1/4 box tube
                        • hows the output on the t case
                          • Originally posted by Burton58 View Post
                            Just needs a new seal thankfully splines are all good
                            My ghetto rear shock setup
                            • hey, the splines might be fine, but make sure the output shaft is not bent. i fubard a driveshaft like that before and the output shaft looked fine.... fixed her up and drove down the road and vibrated my jaw apart.
                              the output shaft was slightly bent
                              • jeep looks like it gets the job done!
