your opinion....
  • #91
    Originally posted by JoeNitro View Post
    as ive said b4 if i were to go to the longarm i will be upgradeing the surrounding components as well. steering, trackbar ect... other than that what else is there to worry about. the jeep has one locked axle. its sitting on 3" lift. i have extended travel shocks and longer breaklines. gastank tuck. you say barely started but if i add the longarm and steering then lock th front its fucking built and still dident cost more than $2500
    total rig cost now is $780
    add long arm, steering, front locker, and trackbar $600 $300 $300 $130
    and shits done for $2110
    thats what you said about the $1000 rig
    thats what geno said, and it turned into a $10000 rig
    ok how many ppl here have blown a tranny cuz they run 33's on stock 3.55 or what ever gearing your jeep has?
    locked or open i cant ever see blowing a tranny.
    tranmissions dont blow, thats unpossible
    i guss i should just stop fighting all of this cuz i did ask for your opinins. thats fine if you dont agree with what i would like to do. some of you have a valid point. but i personaly think it would be cool to have a jeep on 32's 3" lift that is extramely capable with out all that fancy stuff some ppl run. i read sams low cog post about 50 times and i like how it sounds and it makes sense im going to set it up simalar to that.
    i should be a longarm salesman
    i honestly dont see a point in gearing for a 33" tire. id rather have the clearance, added strength and flex of a long arm.
    lower gears makes your drivetrain stronger. and you can make a shortarm flecks like crazy, at 3" longarms are cool, but definately not needed, and only slightly beneficial
    Originally posted by Bigbike View Post
    Isnt oyur rear just a Limited slip not a locker......
    fucking owned
    • #92
      i should rephrase that
      they are beneficial for the reasons i listed, but wont be very high off the ground with 32" tires.
      tnt would be nice at that height (tarz), anything else will drag like a mofo. and without lockers can be a pretty hefty issue
      and im not sure tnt can be run at 3", upper arm hits driveshaft or somethin
      • #93
        This thread is incredible. All of this money could have been spent on an apartment in Florida. Sigh.
        • #94
          32's, Locked Rear, 3.55's
          limited slip isnt a locker
          i had 31's stock, wasnt bad
          32's stock, began to suck but lived with it
          35's stock, sucked fucking ballsacks
          37's and 5.38's locked on each end, loved it
          36's and 5.38's locked, loved it
          35's and 5.38's locked, FUCKING LOVED IT really made the bias 36/37's look slow with those gears
          now im on 33's stock gears and hate it
          • #95
            what long arm kit are you planning to run?
            • #96
              • #97
                • #98
                  had 35's with 3.07's open open, totally sucked, did that for like three months.
                  now 35's arb locked rear 4.88's
                  • #99
                    • you know what. i appreciate your help and you opinions and sugestions, i really do. but im not gonna buy shit for the jeep. im gonna wheel it as it is 3" LSD rear on 32's with stock everything else. you dont like my ill replace it when i need it idea and dont wanna wheel with me thats fine. but i see thousands of people wheel jeeps bone stock and never have problems.
                      #becauseJoeNitro
                      • Originally posted by JoeNitro View Post
                        actually
                        you need longarms
                        • Originally posted by Ktmracer419 View Post
                          actually
                          you need longarms
                          • w/e thanks for your opinions everyone. the jeep is going to remain as it is.
                            #becauseJoeNitro
                            • You mention sam running the low cog long arm thing but he also has 3/4 ton GEARED/LOCKED/BUILT! axles, steering, and big tires. You have none of those things. Personally I don't think 3 inches of lift on 33's requires long arms. I don't think you would get the full benefits of longarms with that set up. It seems like you planned your project to be a certain way and adding long arms would completely change a lot of shit.
                              Also I know my tranny hated me with 33's on stock gears.
                              • You baffle my brain.
