9.5 14B
  • 9.5 14B
    Me and a few friends were BSing in shop and this axle came up, does it have a place in the 4x4 community and would it be a good jeep axle?
    General Tires are
    Some people use the semi-float 14's. Its not bad, but full float versions can be had just as cheap. The housing is smaller, which is nice, but so is everything else.
      Yar, drop anchor, yar.
        I see well I was just wondering your guys thoughts, I brought it up because he was stoked about going from a 10 bolt to a SF 14B
        General Tires are
          If he has a 10 bolt now, anything is an improvement. Chevy's version of the D35...
            I got that, it sucks alot!
            General Tires are
              http://www.pirate4x4.com/forum/chevy...-sf-9-5-a.html
                Doesnt seem to bad It actually looks like a good axle for a mild jeep with a waggy front axle
                General Tires are
                  It is. They are pretty stout. Probably comparable to a 60.
                    Well then, any thought on how to get it adapted to U bolts?
                    General Tires are
                      with u bolts? depending on application move the perches? possibly need u bolt plates?
                      your sense makes zero question.
                        I meant to secure the U joing it uses straps I beilive and If I followed pirates thread its a weak point
                        General Tires are
                          idk if they make diffrent yokes for the sf, but with my ff i just got a new u bolt style yoke.
                          i wouldnt worry to much about them.
                          what is the application for this axle?
                            Usually 3/4 ton Chevy trucks and vans.
                            It would probably be too wide to run with a Waggy 44 front. 8.8 is probably a better match strength/size wise, but the different bolt patterns present an issue.
                            You could buy Zach's (Lycaon) Isuzu rear in the for sale section with a Waggy front. That was my plan originally.
                            97 XJ.
                              yeh i meant what is this going in....
                              what front axle....
                              i thought the 14 bolt sf were 8 lug?
                              edit: guess they came 6 lug too.
