If i put a 2 " lift on my 95 YJ will i need a new drive shaft front or rear im not sure or anything else
lifting
What exactly are you doing for a lift? Springs I assume. If thats the case, your driveshafts will be fine. If you should get any vibration, add degree shims between the axle and the spring to kick the pinion up to match the output of transfercase. You may or may not need to lower the transfercase an inch. If needed, grab a piece of 1" square tubing, drill 3 bolt holes and attach it between your frame and your skid plate. You may also need a dropped pitman arm.88 YJ...kinda. Clayton Hard Arms, V8, 1 tons w/Detroits, twin sticked T-18/NP205, Irok's, MasterCrafts, fuel cell, multi-colored
you shouldn't need a pitman, or a t case drop. Just buy a kit, most will have everything you need in it.Originally posted by Fast Orangeif you piss all over the floor and get 3 drops in the bowl do you count that as good? granted i'm good for a sprinkle or two on the seat, but you leave all of our feet wet, metaphorically speaking of courseOriginally posted by HitItWithSomeSpeedI find adam sandler strangely attractive, it must be josh's fault. god that kid sucks
Originally posted by ruecifur View Postyou shouldn't need a pitman, or a t case drop. Just buy a kit, most will have everything you need in it.95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
if i remember 2" for a yj is just springs and shocks. you can relocated the brake lines and be good
while your doing that take off your sway bar and track bars. they are not needed for a sprung under yj"when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
Originally posted by grundlepunch View Postif i remember 2" for a yj is just springs and shocks. you can relocated the brake lines and be good
while your doing that take off your sway bar and track bars. they are not needed for a sprung under yj95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
