locker issue
  • locker issue
    front locker on my d30 maybe a powertraxx looks like it. but one of the pins has broken and turned sideways. i cannot remove this piece it has sunk itself into its respected place sideways and jammed my front axle into a fully locked position. i also cannot remove the locker itself cause i need to collapse it. any ideas how to get the piece out.
    Dizz dizz go sleep sleep
    Driver 4677 FSM vehicle
    You have no access to the hole straight on correct? can you get a pic of it?
    Im not comprehending how it can jam the axle up if its in the hole it came from.
      its semi in the hole like wedged in it so its in the locked postion and its not fun to drive like that
        uploading pics
          can't wiggle it out with needlenose pliers?
            nah its wedged dang good in there see pics
              in between the cam gears or inside the hole in the cam gear to the right?
                weird, if it were me i would try a skill saw and try to cut the piece in half, may loosen it up enough to move it around, or out. Wont make too much of a mess either. I have a very small pneumatic saw that would work if you want to try it.
                  Don't force it!
                  Get a bigger hammer!
                  I'm sure you will figure it out.
                    when i get home from rc im gonna pull the carrier got to figure out who makes this and im sending them some very detailed pics of this shit and seeing what they can do for me seeing how this happened on street usuage.
                      Have you tried pulling the cross shaft pin? You may get some extra room to work with.
                        That shit happened to nitro at rausch. pretty sure he cut a drill bit down and used it as a pin.
                          Originally posted by customcreationsllc View Post
                          Don't force it!
                          dont force it but get a bigger hammer?
                            It's called finesse with more power.
                            Eric
                              It's a joke
                              You never heard that saying before?
