superior axle super 35 kit vs. ford 8.8 with 3.73?????
  • superior axle super 35 kit vs. ford 8.8 with 3.73?????
    i recently went to change my diff fluid on my rear end(dana 35) on my 2003 tj sport. i have a 3" bds lift with all the bells and whistles and am hoping in the future to run a home-brew 4.5" or 6" long arm kit. When i went to change the diff fluid, i noticed metal shavings in the fluid and when i looked closer i noticed that the pinion mate gears are completely chewed up. So my question is do i fix this and god ahead with superior axles attempt at strengthening the notorious dana 35 or should i start working on a junkyard ford 8.8 with a dana 44 and 3.73's? ive looked at both and the costs will be about the same (about $1020 for the superior kit and about $1200 all in with all the necessary brackets and the axle itself for the ford 8.8) thanks!
      8.8 > shit on a stick > the devil > d35
      act accordingly
        brb swapping shit on a stick in place of the d35 under my comanche
              yes work on a 8.8/d44 hybrid, shit will be sick
              But to be serious it depends on your future goals. If you don't plan on running much bigger than a 35/36" tire, i would go with the 8.8. If you plan on going to 37's or bigger then forget all of the above and go with a 60. Rear 60's can be had dirt cheap, i got mine for 50 bucks basically (most of the time they sell for about 100)
                dude. the guy was just talking about upgrading a d35, and you say go d60. this isnt pirate
                  He was also talking about doing a 6.5 long arm lift, on a tj that is easily good for 37" tires
                    anyone have any suggestions as to where to go for an 8.8 or a dana 60 then since its unanimous to drop the d35 hahah
                      Why not introduce yourself in the Newbie Section. Looks like you own the Jeep I see at UConn all the time.
                      As for the axle I wouldn't spend the money on the super 35 when you could be building a stronger axle for about the same cost
                        i got an 8.8 out of a 06 ranger if your interested. by any chance your name mike?
                          When did the ranger come with 8.8, last I checked the ranger rears were something like 7.5
                          Shane "The Bag" Carlson
                          My "Bucket" Build
                          MilitaryJeepers.com
                          ‚——P--;===±--= <-
                          !‚–’¯ƒ¹¶
                            I *think* the Ranger 8.8's are 28 spline and drums?????? 95+ Explorer are 31 spline and disc.
                            - 99TJ 4.0 4.5 RE springs, Clayton 5in LA stretch, GenRight Armor, 35x12.50 bfg mt, currie hp9 rear w/ 35 spline detroit, hp44 w/ arb and 4340 axles, k/n fipk, banks headers, warn xd9000i
                              DANA 60 !!!! DO IT
