I'll be another to say I wouldn't trust those welded tabs on the bumpers. They aren't very strong just butt-welded like you did.
But, to throw some helpful advice in here, when you are welding you should put the ground closer to where you're laying the bead. You'll get much better penetration. It's hard to tell with how dark my monitor is, but it doesn't look like you cleaned the rust off very well either.
Agreed the cleaner the better.....
95XJ tons 3 link 36s 5:38s
97 F-250HD 7.3 Turbo Diesel
i trust what sam says....because that man knows how to make a fine bumper
the front is tied in exactly how my old winch bumper was. the rear has nut strips in the frame thats bolted threw where the hitch would mount and is welded to the underside of the bumper....
very true good point thnkx. i have pieces that im going to reinforce the d ring tabs with "lateral supports" if you will...
So your old bumper only held onto the front end with 3 bolts on each side??
the old bumper had 4 on pass side and 4 on driver. i have 3 on pass side and 4 on driver 2 of which go threw to the steering box. my old bumper also had a winch this one does not.
