i am not keeping both, the brown one will be stripped of its good parts and scrapped.
the axles under the Red 89 are going to be taken out and returned to armand for his girlfriends xj. the axles/tires on my brown 91 will go under the 89 and the 33" claws in the pics are going on Christinas TJ .
swapped in 89 renix motor with 105k on it. (no leaks)
2x3 L iron frame stiffiners.
2x6 box steel rockers welded in.
roll bar...? if you wanna call it that....
new gastank/fuel pump.
solid floors and unibody (no rust )
my plans are:
gastank tuck.
long arm.
good set of shocks all around. 5150's ?
Raised rear shock mounts (on axle)
5 point harnes
workin on some plans for a mild front exo tied in from the front bumper to the sliders and then a tube fender off the rear bumper followin the wheel well to the sliders.
all of this will occure b4 i switch axles from the 91 to 89. i plan on keeping the 91 on the road while i build this so i can still wheel. should be done late september early october...
That roll cage was in my truck... saved my ass, it works (well not all of it was in my truck but part of it)
hey its better than nothing. And it's a good start so he can finish it later.
