eventually once i am confident with my welds i plan on drilling out the knuckles where the TRE's go into and and welding threaded inserts into them so i can flip my steering to OTK..
took advantage of the weather today, put in some used rear lower teraflex adjustable short arms that i got a really good deal on and put in the a-arm wishbone spacer to prevent the ball joint from wearing out quickly:
found a great deal on custom WJ Alloy shafts inner and outer made by IRO frmo a guy in Jersey for 350$ as opposed to 800$ on the jeep for 6 months only wheeled 4 times total...dont really need them now but for when i run 33's locked on the 30 be alittle more confident in it..
put in used rear lower tera arms
used IRO a-arm spacer
relocate the steering stabilizer
flip the tie rod/drag link
put in IRO front coil retainers
build gas tank skid
then its onto a slow 8.8 build i hope..looking for one with 4:10s, discs, and then just gearing the front to match the rear and running 33's..
hope to be at 4.5-5.5" of lift on 33's with either claytons or IRO's front long arms...and will probably end up trimming my fenders like this fella:
Do you know what roof rack that is? I have seen it before and been trying to figure out who makes it.
thanks
That jeep looks sick, I like those JK rims on it too. Your WJ is really coming along, i hope one day when i new WK is paid off i will be able to lift it and run some 33s on it and get back to wheeling.
