Spend the money and get one of those hinges that Ato Z fab makes with bearings and such. The Detours USA style hinge like that sucks balls.
Project: Doubleyou Jay
hopefully this weekend ( depending on the snow) cutting a hole in my trunk and lifting my tank higher up and possibly trimming rear fenders while im at it...
you guys think this looks good for m rear fenders...once i cut the seam, the two pieces of sheet metal split so i can either fold them over and spot weld them or use rivets..i think the rivets look kind of cool what do you guys think?
http://www.mallcrawlin.com/forum/showthread.php?t=8297
also anyone know where to buy that shnazzy door trim to put on my fenders?-Jason
99WJ 4.0
that looks pretty sweet. From the rest of the work you do, I can tell it won't be a hack job.
As for the door trim stuff, I got some at autozone. It comes in small sections, I forget how long, but it works OK.
felt good to cut up the Jeep today...ill finish tomorrow heres some pics of the tank lift:
after removing my skid/hitch :
cut out the spare tire tub:
gonna cut the brackets and hopefully gain about 6"s in height:
also got rid of my little door thing and put a tj fuel fill bezel in:
99WJ 4.0
order placed from ATOZ for tire carrier hinge kit WJs gonna be getting a rear bumper/tire carrier very shortly i cant wait gonna look sick:
99WJ 4.0
well finished up today:
had to cut my exhaust out of the way to lift the tank which is now loud as fuck i need to get it redone:
new filler/vent holes:
brackets cut down:
tank in:
rear diff where have you been, now i dont need a jack to change my gear oil:
ready to weld:
not proud of these, i can no longer use a 110v welder OR weld anything thinner than 1/8:
ghetto rigged i had to fix the kink in the filler hose, my holes were alittle off, hows the primer? lol:
of course i rushed when taking the measurement for my sheetmetal and its too small so for now ill be using a tarp + the stock cover/cushion + my spare:
very happy with the end result gained ~5 inches maybe more:
-Jason
99WJ 4.0
covered the hole i made, rustoleum hammered is some cool stuff...ill be fixing the carpet it looks shitty..
started trimming the passenger rear fender will finish the driver tomorrow:
before:
after, dont mind the grey primer and the rear cuttage the bumper will cover this:
-Jason
99WJ 4.0
and like how work on the front came out
