Project- Not So CHEEP 1 ton XJ
  • #46
    bad ass.
    • #47
      well after beating the drums off and seeing how the drums would never work it was pretty obvious disks was the way to go.....
      i would never consider drums especially cuz its so damn cheap to do.
      • #48
        UGH..... well...
        once again today i went 1 step forward and 2 steps back....
        the 14 bolt is all welded up and put together just waiting for gearz
        also put my high steer arms and started to put the steering together just to notice that the won ton inverted T setup wont work do to the fact that the axle is moved 2 inches forward and i see no way that the drag link wont bind while articulating.
        kinda sux cuz i originally bought the inverted T setup because i was just going to run it without high steer, to the stock arms on the 60. but unfortunately with the high steer arms it just doesn't look feasible.
        so i have a couple ideas goin threw my brain.
        1. go back to under the knuckle inverted T and sacrifice my track bar angle, and the fact that i cant resell the steering setup
        2. run a new drag link with 7/8ths hiems to the hi steer arms so that i can set my trackbar where it needs to be for good. while running the under the knuckle tierod
        3. just do it right and spend the extra cash for a 7/8ths hiem steering and do away with the inverted T for good, and be happy for till the day i die... unfortunately money is starting to get tight and i really want to be at OER2 with my jeep this time......
        feeling pretty overwellmed and cant afford to rush this....
        • #49
          another idea....
          use the hi steer arms and steering kit.
          since the arms i have only have one 3/4 inch whole on each side, i will need to drill a second whole behind the first on the passenger side and mount the tierod from underneath on the original hole, while mounting the drag link to the top in the new whole....
          or better yet, just drill a new hole in each arm and run the tierod behind the draglink both on the top side of the arms......
          ugh, decisions
          • #50
            fuck it, go full hydro
            • #51
              X2, thats what i'm doin
              • #52
                Can't have full hydro and compete in RCROCS class 2.
                "Ram or Hydro assist steering allowed (no full hydro)."
                99 Dub Ya Jay
                My Adventures Thread
                • #53
                  not a fan of full hydro
                  blow a line you is fucked
                  forget about street driving.
                  why not just bend the drag link a touch?
                  my axle is about 2" forward of stock and i run a longer waggy pitman arm and its fine
                  my drank link is even bent back the wrong way and its fine
                  • #54
                    im familiar with the 1 step forward 2 back.... i hope my jeep makes it to OER... its going to be close
                    • #55
                      we gots half a month.
                      im pretty sure mine would be wheelable by saturday
                      • #56
                        the bend idea might work. but idk... it just seams that if i want to do it right, i should do it now
                        • #57
                          i dont see a small bend as doing it wrong
                          what pitman arm are you running?
                          • #58
                            not saying its wrong... more of the fact im trying to use the kiss method. my arms have a 3/4 inch hole. and that would be great for a 7/8ths heim... i will also do away with the inverted T. and it would be super dooper strong for when i go hydro assist.
                            • #59
                              • #60
                                stock....
