90% of shaved 14bolts i've seen also have been reported to leak constantly. Not that it will stop me from eventually doing it to the one i'm getting for free.
Project- Not So CHEEP 1 ton XJ
Update-
14 bolt- Now has the disk brake swap.. cheep and easy. plus there was no way in hell i could ever rebuild the old brakes. it took about an hour and a half of beating the drums with a sledge to get the fuckers off. Also have a DIY 14 bolt cover kit on the way and a ruffstuff simple 14 bolt swap kit
D 60- tomorrow everything should be welded solid except the track bar, (big thanks to Frank (giantsfan)). I have the heims for the track bar and steel on the way aswell... i also found a set of hi steer arms for cheep, but not sure if i want to use them yet.
driveshaft issues- the front shaft will work fine since teh wheelbase is stretched 2 inches and i was able to trade a friend for a 1310 yoke. For the rear i was told i can get a 1350 yoke then i was looking up conversion u joints from a 1310 to a 1350 which should work just fine for now... maybe later ill put a dana 300 and a new driveshaft in...
Gearz will be ordered Saturday, just waiting for corey
I picked up a dookin piece of 2x6 for the cross member today. still trying to think of how i wana go about mounting it since my lower arms are kinda in the way..
so with any luck at all
, this thing should be rolling by the end of the weekend, and hopefully can do the gears the following weekend.
Originally posted by Ktmracer419some people choose video games
