shits DOOKIN
The new and improved project blue rain
ill have moser inner shafts, yukon super joints with full circle clips and nitro axle and gear shafts
the moser inners i'm not worried about, the yukon super joints are capable of like 12,000 ft lbs of torque or something silly like that, and the outer shafts have a lifetime warranty
i was fine on the moser inner and outers with spicer 5-760 x' joints with half clips for about 2 years, its just that when those finally let go i just swapped in stock replacements and the cheapest alloy shafts i could find. well all of those broke. i think i will be fine with the new setup with my weak link being the outers. a dana60 is out of the picture for a while. I can either fix my dana44 for 300 bucks, or build a 60 for $3500. If i do a 60 it would need to be narrowed and i would need an 8 lug rear, get new wheels and the price keeps adding up. so keeping my 44 is appealing.
your 30 is the least polished ever, it doesnt even have metallic paint dudeOriginally posted by HeavyMetal View Postand u say i polish my 30...
THIS is a polished 30
Sam you've probably seen this already, but Longfield is making birfs for 44 front axles... Not sure if they are just for Rubicon front 44s, but there are some threads circulating around pirate. http://www.pirate4x4.com/forum/showt...=d44+longfield
I also had a completely off topic question for you. Did I see you had some sort of Torque Converter lockup switch in your rig? If so what do you use it for exactly?Jeep - every bump is a steering opportunity
also this was in that thread thought it was pretty interesting.
PRODUCT ............................................ FT.LB. TORQUE.... Deg. of TWIST
Yukon 4340 Dana 60 35 spline short side axle.........12,000......130
Stock Dana 60 35 spline short side axle ..................6,500........35
Yukon 4340 Dana 44 30 spline short side axle ..........5,800 .......35
Stock dana 44 30 spline.......................................5,000 ........35
Yukon 4340 Birfield Eliminator kit (ear failure)............5,500.......50
Longfield Toy 4340 30 spline (shaft failure)...............8,500.......175
Longfield Toy 4340 27 spline..................................6,500..... ..75
Stock Toyota Birfield.......................................... ..4,200 ......45
Stock Toyota Inner Axle........................................5,000 .......45
All Pro "Profield".................................... .... .......... 3,500 ......30
TJ Rubi Longfield front...........................................6, 800.......75
TJ Rubi Superior front (shaft failure).........................5,800........40
TJ Rubi US Alloy front............................................5 ,000........40
TJ Rubi Yukon front............................................. .4,100........50
TJ Rubi stock front (ear failure)...............................2,500...... ..10
TJ Rubi stock front (ear failure)...............................2,000...... ..10Jeep - every bump is a steering opportunity
