96 cherokee classic
4.0
aw4
np231
whatever tires i found for cheap the month before
15x8 allied 32 bolt black beadlock wheels with 2.75" bs (only on the rear, need to build up monies for 2 more)
Dana44 front
out of a 1987 jeep j-10
chevy half ton disc brakes
yukon 5.38 gears
30 spline detroit locker
30 spline alloy/chromo shafts
warn premium locking hubs
rockkrusher diff cover
high clearance control arm brackets
custom over the knuckle, inverted "T", one ton steering using chevy tie rod ends
u bolt style pinion yoke
Dana60-2 rear
out of a 1973ish international milk truck
caddilac eldorado disc brakes
yukon 5.38 gears
strange engineering 35 spline spool
35 spline moser alloy shafts
whole milk friction modifier (increases locking action of the spool)
SOLID diff cover
ruffstuff antiwrap leaf spring perches
high clearance shock mounts
3" rustys coil springs
custom longarms using a mish mosh of 7/8" heims, currie jhonny joints and ol' fashioned bushings (radius arm)
tnt customs heavy duty trackbar w/ brace and 1/2" bolt mod
some sort of cheap pos xj 4.5" lift shock in front
old man emu nitro's in back
fancy front brake hoses off of a late 70's dodge van
dodge dakota rear brakeline
re 4.5" rear leaf springs (sagged to just about flat)
1.5" rocky road outfitters lift shackles
dpg adjustable bumpstop plates
4.1" rubber bumps in back
exploded hockey puck bumpstops in front
tnt customs unibody stiffeners
tnt customs high clearance crossmember (modified w/ belly skid)
custom 1/4 panel armor (with removable flares to keep the local 5-0 happy)
custom high clearance front bumper
custom 2x6" box tube rocker panels
high clearance fuel tank tuck w/ skid
heavy duty sye with stock front cv shaft in the rear
awshifting shift control module
10lb co2 tank
grand cherokee 60/40 split rear bench seat
sweet jvc hd radio
doorless mod
custom rear bumper wheelie bar
old thread:
http://mrmontez2000.proboards70.com/...ay&thread=8556
the new plans are:
3 link
trussed axles
plated front frame
rear bumper
