The new and improved project blue rain
  • #91
    wtf.
    • #92
      notched truss
      • #93
        looks good sam
        • #94
          axle trimmage
          • #95
            maybe now your jeep will survive a jump w/o ticking after.
            • #96
              next order of importance:
              non-gay t-case shift linkage
              clocking ring (dont know how i feel about drilling into my aw4)
              custom flat bellied crossmember (not going to be exactly as pictured but i am going to modify it)
              new aw4
              maybe a new np231 (jb weld is holding up just fine)
              • #97
                t-case linkage is in.
                http://www.bsfab.net/?p=26
                did it like he did, but a lil differently with less work and parts.
                I simply took the old shift lever on the t-case flipped it up, cut a notch in it, bent it, filled in the bent part with weld and simply adjusted the new linkage to fit. in 2 hi it rests against the case, so win. in 4 lo its almost pulled straght to the handle end lever, I just hope when i clock it It will still work for me. right now it is perfect.
                • #98
                  hmm I like that shifter idea. Mine is shitty going back into 2wd. Pretty sure that's a common 242 problem though.
                  What the deal with the clocking ring? What does that accomplish?
                  • #99
                    it clocks the t-case upward so you get a few more inches of ground clearance
                    • oooo ok thanks
                      • oh hey
                        completely flat crossmember is in
                        t-case is about 3/4" above the bottom of the framerails.
                        still gotta clock the case to get the driveshaft to clear the crossmember.
                        once its clocked it almost feels like a waste to get a belly skid in there. that shit will be so high up. all a belly skid will do is cost me clearance (lo9l)
                        • Nice Sam!
                          Did you order coils yet?
                          FUCKING GENO
                          • i have 2 pairs of no name 2-3" coils ima try
                            • Thats sick sam, id really like to see pics of the setup, ive never seen a tummy tuck that high on an xj. Did you have to mod the floor?
                              • i clocked the t-case tonight
                                didnt bother making a jig because it looked simple enough to eye it up.
                                i fucked up one hole and had to file it out, but it sits nice in there now.
                                i bashed my floor up a little bit to clear it, but the t-case is still up against it, more bashing is in order.
                                the bottom of the case is a good 1.5" above the bottom of the rails now
