Originally posted by CumminsJeep
My 1950 Willys Trail Rig
haha yea probably try to get in on the roof day 1 or 21950 Willys Trail Rig
July, I hope. I might even be driving it by Monday.Originally posted by Riot View PostThis is a crazy build.
When do we get to see it in action!?
I built both shafts today. Another major dialemma for me. I want to have some strong stuff in the jeep, but I also want it done.
The rear shaft is a 1310 Double Cardan at the Case and 1350 at the axle. My transfer case is 10 spline output. You can get a 1350 CV Yoke for about 100 bucks and that will probably make the output the weak link. I want to probably upgrade to a 32 spline, however that is about 400 and I think the yoke is like 50. Right now I am just trying to get it done, so Ill probably just carry an extra shaft for now and start saving for the 32 spline kit if/when I put my 203 range box in.
The front shaft is 1310 double cardan at the case and 1330 at the axle. For this I just worked with what I had. Again 10 spline. I will probably leave this unless I find it breaking a lot
Pictures soon1950 Willys Trail Rig
Rear driveshaft went in today, Never seized and tightened all of the fasteners and aligned it, then decided it was time to go for a little ride.... And it was AWESOME. It rides really nice, handles really nice, and I seem to have gotten the squat dialed in pretty well... It is pretty neutral, does not lift at all.
I flexed it out on some tires and everything seems to work as I designed it, and It does not rear steer too bad. Here's some pics
I ordered a hot rod builder exhuast from jegs... should be in tomorrow
Admittly not the best setup but it fits. Theres not very much weight getting tossed around back there either. I may change it eventually along with 2378930475 other thingsOriginally posted by fullwidthxj191 View PostI'm interested in your shock setup, it doesn't seem like that setup would give a lot of control over the body? I would imagine you get a ton of droop though.
Oh and this is why you weren't included in the poll, you actually get shit done
Came home from work today, 2 boxes from Jegs (exhaust pipe) and 1 box from BTF (Limit strap) I got some work to do this weekend
This is what I ordered in 2.25, the box is pretty big
Nope, the headers are squeezed inside the framerails. The fenderwell headers are aftermarket and cool, for street use. Offroad I think exhuast run under the rockers would get destroyed. Plus if you look back you might notice my cage tie ins on the outside of the frame rails where that style exhuast would go... So it is out of the question for me. My headers are Edelbrock TES, the application was for my old '89 s10. I had to modify them a little to fit in my jeep. Mainly to clear the clutch slaveOriginally posted by Jeepbonehead View Postthe headers drop right outside the frame rails right? i'm pretty sure thats the way all old jeeps/willy's were
Fitting an exhuast is going to be a trick, there is not much room, that is were the wider framed YJs and TJs have an advantage. I just need to add some back pressure and quiet it down, and keep it from getting smashed.
I might end up running these if there is no room for a muffler... http://www.jegs.com/p/Car-Chemistry/...44688/10002/-11950 Willys Trail Rig
or you can get glasspack look-alike mufflers with the inserts in them
http://www.carchemistry.com/shop/ind...ct_detail&p=94
pretty pricey, they probably sound better than glasspacks and maybe quieter, which I like. Versus a 12 inch long summit glasspack is 20 bucks...1950 Willys Trail Rig
