Project: Thunder Kiss '89
    b&m "ripper" short throw came in today, ordered from another member on SCCoA
    HOPEFULLY this will solve my shifting problem, the centering springs are nice and tight on this, fuckin sloppy as shit on my stock one
    1945 Willys-Overland CJ2A
      definitely found the problem with the stock shifter
      got the b&m installed, tight as hell. no more jamming it into gear
        This thing sucks
        Dizz dizz go sleep sleep
        Driver 4677 FSM vehicle
          Didn't you own a white version of this car at one point, Zach?
          Is it egg nog season yet?
            yeah i traded it for a stealth r/t TT which turned out to be a junk junk heap so i sold it
              Originally posted by fizzy View Post
              This thing sucks
              eat shit
                Originally posted by Lycaon View Post
                eat shit
                With crushed red pepper?
                  so since i got this car it has been in the habit of marking its territory wherever i leave it parked. i was laying under the front end of the car last night while the oil was draining and as i was looking up i found what appears to be the source of my leak. i thought it was the oil sensor on the side of the pan which i had heard was a common spot for them to leak from but as i was looking up above where the rack rests under the engine cradle i noticed through on of the spy ports on the crossmember that the oil pan was resting right on the cradle itself. more investigation showed that both of the stock hydraulic motor mounts had collapsed causing the engine to settle down onto the crossmember so im about 95% sure of what im dealing with...
                  LUCKILY i was able to score a sweet deal on a 351W(Thanks Dan!) so ill be spending the next few months(and paychecks) putting it together to complete my "SC-R" conversion. the car is going up on jackstands for the winter so i can take care of the brakes and a few undercarriage mods, hopefully a transmission rebuild, and if i have to take the 3.8 out to change the mounts and oil pan anyway i may as well have the 5.8 ready to go if i need it
                    http://www.sisoffroad.com/forums/sho...80&postcount=5
                    much cheaper than wiring up the EFI, ask me... i know...
                      302 intake wont fit on a 351 spanky. the deck height is taller therefore the 5.8 manifolds are wider. its the thought that counts tho <3
                        that's what i thought.... but i was hopeful it would
                          Nice! already coming apart. Now put it in!
                            gotta get new parts first! it wont fit in stock form, lol
                              lookin at this cam kit for when i open it up
                              http://www.summitracing.com/parts/CCA-K35-421-8/
                              and bracketry
                              http://www.ebay.com/itm/94-95-FORD-M...sories&vxp=mtr
                                Without upping compression or changing cylinder heads its not really worth the money to go to a roller cam.
                                Spend the money on a better intake or ignition.
                                Im not sure on those either but you may have to watch the lift for piston clearance.
                                http://www.summitracing.com/parts/CCA-K35-238-3/
                                Or something like this if there is room
                                http://www.summitracing.com/parts/CCA-K32-225-4/
                                I think that would be getting close on piston clearance though. That and with a stock head, its just not going to make much difference going any bigger.
                                Without a split duration you will have a little better idle and it will be a little friendlier at idle with the fuel injection. Depending on setup though. I assume your gonna run it with a MAF?
