Project Black Betty
  • #46
    • #47
      Looking good, i like the cable idea on the disco's too...
      DONT GET MAD GET ROWDY !!!
      • #48
        So yesterday and today I mounted the other slider, made the cable disconnects, installed the new brake lines, and changed the oil. When I bled the brakes, both calipers were full of water. The fluid was black, you couldn't even see through it. It stops so much better now.
        I flexed it out but I couldn't find anywhere to get it high enough so the rear tire would come up. Still, at that height, no rub and plenty of room. I'm very happy with the way it turned out.
        rear line was a little long so I used a spring to hold it up and out of the way.
        And finally, all ready for RCROCK. As she sits now:
        • #49
          • #50
            Oh yeah, thanks for the idea with the disconnects Adam. Easy, cheap, and works great. Can't ask for much more there
            • #51
              Look sick dude, get some good pics of those sliders in action, they saved my ass many times.
              • #52
                more pics of her
                • #53
                  jeeps looking good man
                  • #54
                    This weekend I finished up my one ton steering. I ended up having to make a bracket to put on a steering stabilizer since I was getting pretty bad death wobble. Steers like a dream now though.
                    closeup of the bracket. U-bolts are from the drive shaft of a '73 Cuda
                    • #55
                      you shouldnt be getting any DW.. your angles look perfect. check the axle end bolt on the trackbar and make sure its tight and not ovaled out and all that other standard crap to check.
                      • #56
                        The track bar and bracket are new. I noticed when I was mounting the bracket that the track bar bracket would move slightly under a turning load. I moved one bolt maybe 1/4 turn. The movement stopped and at this point I had the stabilizer on so I didn't get to test it with or without the stabilizer.
                        Would a very slight movement (less then 1/8") cause DW?
                        • #57
                          that angle iron looks sick
                          • #58
                            Yeah, I should have made it out of diamond plate. When I get home I`ll radius the ends and make it all nice a sexy like
                            • #59
                              i'd 4 link it. less binding
                              • #60
                                How could you 4 link that?
                                I dont think I have to worry about binding, that front end is looser then Brittney Spears` rear end
                                ZING got her
