Gen. Forest Build
  • #61
    More pictures!
    So after the hill climb stuff we found some rocks that were being used to separate the dirt bike trails from the vehicle trails and we decided to play around on them.
    The first rock was kind of just sitting there with no purpose.
    So we did this.
    Postcard?
    Then I got to play on the rocks. ( I assure you i'm not throwing up "deuces" I was "representin 11,000 yo")
    Then we decided I should climb the rocks.
    Departure angle? I has none.
    Approach angle? How do you mess this up?
    Because well, I'm awesome.
    This is what I was looking at from inside the truck.
    And I also so saw this....
    So I rolled my truck off the rocks we took pictures with the vehicles.
    Then, I took a picture and we left.
    It was overall a fun day.
    • #62
      Took some pictures for ford fullsize forum thread pertaining to the ttb front axle setup and the flex it gets. Figured I'd post my pictures in the build thread.
      Couldn't get something big enough to flex it all the way
      • #63
        Current spec sheet of the truck...
        Installed:
        4.9 I6 (stump puller)
        M5OD-R2 (replaced in 4x2 to 4x4 swap)
        BW 1356 (part of 4x2 to 4x4 swap)
        4x2 to 4x4 swap
        87-91 nose swap
        k&n open element air cleaner (previous owner)
        4/6 lift brackets
        6" TC springs
        Rear Shackle Flip
        2" lift shackles
        triangle spring 2.5" wide replacement springs
        1.5" pinion correction blocks
        superduty front shocks with cut sleeves
        procomp es3000 11.23" travel rear shocks
        33's adventuro m/ts
        Tranny and t-case tuck
        custom 41 7/8's inch rear driveshift
        3.55 aussie locked d44 ttb
        3.55 open 8.8 welded tubes (3.55's are a step up from the factory 2.73's btw)
        4.9 super cooling radiator
        full 3 inch exhaust with a spiral core bullet muffler
        custom rear bumper
        cut up front bumper
        frame repair and reinforcement
        rear fuel tank delete
        Tuffy box
        pioneer deck
        sony amp
        diablo 5x7's
        cb
        storage visor install
        a pillar guages
        2 5/8's tach
        6" lights*
        12" sony sub
        Sliding Rear Window
        Waiting:
        9" rear end
        dual battery set up
        sun visor
        electric fan
        8000lb winch
        3 point y harness
        Wants:
        Deaver 5.5's
        Long Arms
        Rear LS or locker
        36's
        Fox 2.0's or Bilstein 5160's front
        torque'ier cam (i know i know)
        STaK 3 speed monster box
        Cage
        hella 500f's
        • #64
          flat rock trails?
          youll have to hit me up sometime to go wheeling
          • #65
            Originally posted by justtorchit View Post
            flat rock trails?
            Ok will do, we've gone out 2 weekends in a row its been pretty nice.
            • #66
              http://contour.com/stories/playing-i...-before-school
              • #67
                what about sunday???
                TeamRedNReckless
                98 zj 4" 31's no fenders or doors -Retired-
                4x4 Abbreviations
                • #68
                  maybe sunday, rumor has it that frejeep's tranny is stuck in reverse (not so much rumor considering I was there today)
                  • #69
                    but that takes and hour so i have heard
                    TeamRedNReckless
                    4x4 Abbreviations
                    • #70
                      45 minutes to take it out if we dont dick around
                      • #71
                        2 days if we do
                        TeamRedNReckless
                        4x4 Abbreviations
                        • #72
                          2 days if we do
                          EXACTLY
                          • #73
                            Playing in the snow at wrpooles girlfriends house.
                            http://contour.com/stories/snowy-suspension-testing
                            • #74
                              that was me "jumping in the back" of mreecew's truck
                              TeamRedNReckless
                              4x4 Abbreviations
                              • #75
                                Added some lights off the bronco this weekend. Hopefully gonna put some ambers on the tilted section of the bar sometime.
