- 2wd.......Two Wheel Drive.
- 4FT.......Four Wheel Drive, Full Time.
- 4LO.......Four Wheel Drive Low.
- 4PT.......Four Wheel Drive, Part Time.
- 4wd.......Four Wheel Drive.
- AAL.......Add A Leaf.
- ABS.......Anti-lock Brake System.
- AC or A/C.......Air Conditioning.
- ACC.......Accessory.
- ACM.......Airbag Control Module.
- AECM.......Airbag Electonic Control Module.
- AEV.......American Expedition Vehicles. A vehicle modification/conversion shop, located in Montana.
- AMC.......American Motor Corporation. Owners of the Jeep brand from 1970-87.
- ARB.......ARB Corporation named for its founder, Anthony Ronald Brown. Aftermarket manufacturer.
- ASDM.......Airbag System Diagnostic Module.
- AT (A/T).......All Terrain tire.
- ATC.......Automatic Temperature Control
- ATF.......Automatic Transmission Fluid.
- AtoZ.......A to Z Fabrication. Aftermarket Fabrication.
- AVG ECO.......Average Fuel Economy.
- AW4.......Automatic Transmission used on the XJ since 1987.
- AWD.......All Wheel Drive.
- AX15.......5 speed manual stick in a pre-99 6 cylinder TJ.
- AX5.......5 speed manual stick in a pre-99 4 cylinder TJ.
- BB .......Budget Boost (small, 2" lift).
- BCM.......Body Control Module.
- BFG.......BFGoodrich Tires.
- BFH.......Big F-ing Hammer.
- BL.......Body Lift. Spacers between the frame and body/tub of a vehicle.
- BPE.......Bar Pin Eliminators.
- BS .......Backspacing. Wheel hub location in relation to outside edge of rim.
- BTT.......Back To Top.
- BTW.......By The Way.
- BUX.......Built Up Export.
- C-101.......Jeepster/ Commando 1967-1973. Part Jeep CJ and part Jeep Wagoneer.
- CAB.......Controller, Antilock Brake.
- CAL.......Calibration.
- CAT.......Catayltic Converter.
- CB .......Citizen Band Radio.
- CCD.......Chrysler Collision Detection (vehicle communications bus).
- CCV.......Crank Case Ventilation.
- CEL.......Check Engine Light.
- CG or COG.......Center of Gravity.
- CJ....... Jeep models 1944-1986.
- CJ-2A.......Civilian version of the MB, split windshield.
- CJ-3A.......Updated version, single pane windshield
- CJ-3B.......High hood version of 3A to fit larger engine
- CJ-5.......Early years were 81" wheelbase, later years were ~84". Built until 1983.
- CJ-5A.......based on the M38A1 design
- CJ-6.......Stretch version of CJ-5, 101" wheelbase
- CJ-6a.......based on the M38A1 design
- CJ-7.......smilar to late CJ-5, but with ~94" wheelbase. Built until 1986.
- CJ-8 Scrambler.......Scrambler Pickup, stretch version of the CJ-7, 104" wheelbase.
- CJ-10.......Heavy Duty Truck, Military airport Jeep pickup - 2wheel drive
- CMTC.......Compass/Mini-Trip Computer (module)
- COG.......Center Of Gravity.
- CPS.......Crank Position Sensor.
- CV.......Constant Velocity Joint.
- CVT2/CVT3.......Continuously Variable Transmission
- D30.......Dana 30 axle.
- D35.......Dana 35 axle.
- D35C.......Dana 35 axle with C clips. The 'C' stands for custom. They are custom because they are shipped incomplete from the Dana factory to Chrysler. Final assembly was done by Chrysler.
- D44.......Dana 44 axle.
- D44a.......Dana 44 axle with an aluminum housing
- D60.......Dana 60 axle.
- DAB.......Driver Airbag
- DC .......DaimlerChrysler. Owners of the Jeep brand since 1998.
- DD....... Daily Driver.
- DDM.......Driver Door Module
- DJ DJ Postal.......2wd Jeeps. 1952 - 1973 by American Motors Corporation
- DLC.......Data Link Connector (same as EDC)
- DOHC.......Dual (or double) OverHead Cams.
- DOT.......Department of Transportation
- DRB.......Digital Readout Box
- DRL.......Daytime Running Lights.
- DPA.......Dropped Pitman Arm
- DS....... Death Shake (same as DW)
- DTE.......Distance To Empty
- DW.......Death Wobble. Violent shaking of the vehicle. (same as DS)
- ECO.......Intantaneous Fuel Economy
- ECU.......Engine Control Unit (same as ECM)
- ECM.......Engine Control Module (same as ECU)
- EDC.......Engine Diagnostic Connector (same as DLC)
- EGR.......Exhaust Gas Recirculation
- EFI.......Electronic Fuel Injection
- ESP.......Electronic Stability Program
- ET .......Elapsed Time
- FAQ.......Frequently Asked Questions.
- FC .......Forward Control Trucks 1957 - 1966
- FIPK.......Fuel Injection Performance Kit. Sold by K&N.
- FSJ.......Full Size Jeep (SJ's and J-trucks).
- FSM.......Factory Service Manual.
- FWD.......Front Wheel Drive
- GC .......Grand Cherokee
- GPS.......Global Positioning System.
- HCU.......Hydraulic Control Unit
- HD .......Heavy Duty
- HEX.......Hexagon
- HF .......Harbor Freight. A discount tool store.
- HID.......High Intensity Discharge. A lighting system that produces an intense, white light.
- HO.......High Output
- HP.......High Pinion
- HTH.......Hope this helps, happy to help.
- HU .......Head Unit. The main part of your stereo system.
- HVAC.......Heater, Ventilation, Air Conditioning system.
- I4.......Inline four cylinder engine.
- I6.......Inline six cylinder engine.
- IAC.......Idler Air Control Valve
- ID or I/D....... Inside Diameter
- IFS.......Independant Front Suspension.
- IOD.......Ignition Off-Draw
- IR.......Ingersoll Rand. Air tool manufacturer
- IRS.......Independant Rear Suspension.
- JTEC.......Jeep Truck Engine Controller (PCM)
- KJ Jeep KJ .......Liberty models from 2002+ (Cherokee in Europe).
- L.......Liter
- LA .......Long Arm. Refers to length of control arms.
- LCA.......Lower Control Arms. (same as LSA)
- LD.......Left Door.
- LE.......Light-Emitting Diode.
- LHS.......Left Hand Drive.
- LJ.......Unofficial (?) letter code for the Jeep Wrangler Unlimited 2 door 2004+.
- LOM.......Lamp Outtage Monitor.
- LR.......Left Rear.
- LSA.......Lower Suspension Arm (same as LCA).
- LSD.......Limited Slip Differential.
- LWB.......Long Wheel Base.
- MAP.......Manifold Absolute Pressure sensor.
- MET.......Metric.
- MIC.......Mechanical Instrument Cluster.
- MJ Jeep MJ .......Comanche, Compact Pickup models from 1986-92.
- MML.......Motor Mount Lift.
- MPI.......Multi-Port Fuel Injection.
- MPG.......Miles Per Gallon.
- MPH.......Miles Per Hour.
- MSTM.......Memory Seat Module.
- MT (M/T).......Mud Terrain tire.
- MTR.......Motor.
- MUX.......multiplexed.
- NP .......New Process (same as NV).
- NP231.......Command-Trac Transfer Case (2HI - 4HI - N - 4LO).
- NP242.......Selec_Trac Transfer Case (2HI - 4PT - 4FT - N - 4LO).
- NP249.......Quadra-Trac Transfer Case (4 All Time - N - 4LO).
- NV .......New Venture (same as NP).
- NV247.......Quadra-Trac II Transfer Case.
- NV3550.......5 speed manual stick in a post-99 6 cylinder TJ.
- NWS.......Not Work Safe (this thread might get you fired at work)
- O2 .......Oxygen (usually in reference to an oxygen sensor).
- OBA.......On Board Air. A system of a tank and/or air compressor located on a vehicle.
- OBD, OBDI.......First generation of On Board Diagnostics.
- OBDII.......Second generation of On Board Diagnostics (1996+).
- OBW.......On-Board Welder.
- OD or O/D.......Outside Diameter.
- OD.......Odometer.
- OHV.......Off Highway Vehicle
- OEM.......Original Equiptment Manufacturer.
- OME.......Old Man Emu. Aftermarket Manufacturer.
- ORV.......Off Road Vehicle.
- OTK.......Over The Knuckle.
- PAB.......Passenger Airbag.
- PB PB Blaster........ A penetrating liquid.
- PCM.......Powertrain Control Module.
- PDC.......Power Distribution Center.
- PDM.......Passenger Door Module.
- POS.......Piece Of Sh--.
- PS or P/S.......Power Steering.
- PSI.......Pounds per Square Inch (of pressure).
- PSF.......Pounds per Square Foot.
- PRNDL.......Park, Reverse, Neutral, Drive, Low.
- PRNODL.......Park, Reverse, Neutral, Overdrive, Drive, Low.
- PTC.......Positive Temperature Coefficient.
- PTO.......Power Take Off.
- QD.......Quick Disconnect. Installed on the anti-sway bar.
- RA .......Road Armor.
- RC .......Reverse Cut.
- RD .......Right Door.
- RE .......Rubicon Express. Aftermarket manufacturer.
- RFI.......Radio Frequesncy Interference.
- RHD.......Right Hand Drive.
- RK .......Rock Krawler. An aftermarket suspension company.
- RKE.......Remote Keyless Entry.
- RPM.......Revolutions Per Minute.
- RR.......Right Rear.
- RTI.......Ramp Travel Index.
- RTV.......Room Temperature Vulcanizing. A product that is used to form gaskets.
- SAE.......Standard American Equivalent. You know, tools that aren't metric.
- SAS.......Solid Axle Swap. Swapping in a solid front axle to replace IFS.
- SE .......Jeep's basic trim package.
- SEMA.......Specialy Equipment Market Association.
- SF .......Superflex. A lift option for Rubicon Express lift kits.
- SFA.......Solid Front Axle.
- SJ.......Jeep Grand Wagoneers, Trucks from 1963-92.
- SOA.......Spring Over Axle.
- SOHC.......Single OverHead Cam.
- SRS.......Suplimentary Restraint System. (AKA airbags)
- SUA.......Spring Under Axle.
- SWB.......Short Wheel Base.
- SWR.......Standing Wave Ratio.
- SYE.......slip Yoke Eliminator. Installed on transfer case to decrease driveline angles.
- TB.......Throttle Body.
- TBI.......Throttle Body Injection.
- TBS.......Throttle Body Spacer.
- TBT.......Toys by Troy. Aftermarket Manufacturer.
- TC....... Transfer Case.
- TCM.......Transmisison Control Module.
- TJ .......Jeep TJ Wrangler models from 1997-05.
- TJL, TJ-L.......Unofficial letter codes for Jeep Wrangler Unlimited 2004+.
- TPS.......Throttle Position Sensor.
- TRE.......Tie Rod End.
- TSB.......Technical Service Bulliten.
- UCA.......Upper Control Arms. (same as USA).
- UJ.......Universal Joint.
- USA.......Upper Suspension Arm (same as UCA).
- US/M.......U.S. to Metric [button].
- VC....... Viscous Coupler.
- VF.......Vaccum Flourescent Display.
- VIC.......Vehicle Information Center.
- VIN.......Vehicle Identification Number.
- VSS.......Vehicle Speed Sensor.
- VTSS.......Vehicle Theft Security System.
- WJ.......Jeep WJ Grand Cherokee models from 1999-04.
- WD-40.......Water Displacement, Formula 40. A common oil used to do pretty much anything.
- WK.......Jeep WK Grand Cherokee models from 2005+.
- WMS.......Wheel Mounting Surface.
- WOt.......Wide Open Throttle.
- WTF.......What The F-.
- XJ.......Jeep XJ Cherokee and Wagoneers from 1984-2001.
- X.......Jeep Wrangler Trim/Option Package.
- XM.......A satellite radio service.
- YJ.......Jeep YJ Wrangler models from 1987-95.
- ZJ.......Jeep ZJ Grand Cherokee models from 1993-98.
Acronyms and Abbreviations for newbies
