Here it is, 6 inches of lift 33's, tummy tuck/ belly up tranny and t case set up, 3.55 axles trimmed rear lower fenders, sectioned frame and custom rear drive shaft and all the other fun stuff we have done to it.
1991 bowl of rice, painted red and black on a pile of nicely stacked scrap metal and 4 35's.
Lol I agree, once I have the money it's getting either of the 2 sizes but for now I can deal with just 33's these ones have a ton of life left so no reason to get rid of them
Did the exhaust on friday night. Ended up cutting the second cat off and leaving the first cat coming off the Y pipe and using the broncos 3" exhaust with the lowback muffler and adding in a few inchs to suit the longer truck. Sounds a lot better now. Also heres a picture of the truck in the light micro flexing on a 1.5 to 2 little hill thing.
Found a website that finds the total gear reduction ratio for your vehicle once you put in your specs. And if you don't know them they have drop down menus with different trannys, t cases and underdrives and doublers. http://www.grimmjeeper.com/gears.html after pluggin in all my stuff for this truck it comes out to 41.64:1 in 1st and 4lo. And with the EFI 4.9 making 275ft lbs at 2000rpm in 1st and 4 lo i'm putting down 11,451ft lb,'s. Try it out and find out what your running I found the site really cool. Well now that I'm done with my little ad thing heres some new pictures.
So yesterday my father (frejeep14) and will (wrpoole) and I decided to go out with just my truck and my fathers jeep, and went to a place in plainfield yesterday, for a kind of shake down run on the f-150, which was really just us procrastinating on doing some work that had going on back at the house. But all in all we had a good time and in turn also found some glitch's and gave ourselves some little b.s. stuff to fix, when we get some down time at the house.... well pics!
Decided to play around on some rocks on the side of the trail to get some flex shots.
Then decided that the rock I was on wasn't big enough
Decided to get comfy and take a look at what was going on under my truck to check everything out
And found out my back spacing isn't perfect.... or my bumpstops need adjusting
Just to show springs and shock movement
Frejeep's turn?
Moved my truck to make room
More pics in a minute this post just got looong
