Mounted master and attached it to the pedal:
1st try:
That broke off because the point the pushrod mounted to on the pedal was too far and too high so i made this up (kinda hard to see):
I got a starter and put it in. It starts and the clutch works good but I was hearing a loud ginding noise from somewhere in the clutch area. Didnt go away with clutch in or out so I pulled the starter and pop started the truck to make sure it wasnt the starter grinding. Upon further inspection I found that the pressure plate i am using is too thick and is grinding up against the clutch fork
Hard to see but the pressure plate is on the left and the round piece pressed up against it is the pivot point of the clutch fork.
I was almost done now it all has to come back out
1st try:
