4 springs that dont have much intensity to them attached via hooks/holes at the corners of the plates oughta do a body good
So, more camera mount stuff. (engineering minds of SiS)
seems overkill to me, no?Originally posted by Danksters View Post4 little post sliding in holes drilled in the upper plate
wouldnt 4 springs at 4 corners locate the plate fine enough? this isnt gonna see a lot of load, the cams only 5 pounds- Will
Threaded rod. One plate has them welded to it, then between the two plates a coil spring, then a bolt to hold the two plates together.Originally posted by HeavyMetal View Postseems overkill to me, no?
The foam and the coil springs will keep the two plates separated while and force from the body will be absorbed in the upwards motion.sigpic
Yes, I agree with you, I was just expanding on what Phil had said. You probably don't need pins and springs.Originally posted by HeavyMetal View Postseems overkill to me, no?
wouldnt 4 springs at 4 corners locate the plate fine enough? this isnt gonna see a lot of load, the cams only 5 poundsYou're a ___________
i dont follow totally..Originally posted by Buffalo Phil View PostThreaded rod. One plate has them welded to it, then between the two plates a coil spring, then a bolt to hold the two plates together.
im envisioning a piece of foam sandwiched between 2 plates by just 4 coil springs "tying" the 2 plates together, compressing this foam and using that as the sole barrier- Will
So the bolt would just be there to keep the upper plate from flying off right?Originally posted by Buffalo Phil View PostThreaded rod. One plate has them welded to it, then between the two plates a coil spring, then a bolt to hold the two plates together.
The foam and the coil springs will keep the two plates separated while and force from the body will be absorbed in the upwards motion.You're a ___________
why not use 2 pieces of box the came size. weld a tab in them and they get another piece of box that is somewhat snug on those 2. weld the big one partially onto the bottom put a shock absorber in there and slide the other one down on top of it. there it is sleeved and not going to fall over. While still allowing dampening1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
What? Draw a picture or STFUOriginally posted by Cletus View Postwhy not use 2 pieces of box the came size. weld a tab in them and they get another piece of box that is somewhat snug on those 2. weld the big one partially onto the bottom put a shock absorber in there and slide the other one down on top of it. there it is sleeved and not going to fall over. While still allowing dampening
box 1" od 4 feet cut in half
box 1" id 1 foot
make notch in 1"od slide a tab in weld it in 6" down from top on both halves
slide 1" id down the 1" od about 4" weld it to bottom half
insert shock absorber
insert top 1" od into the sleeve
bam win
and matt youre stupid for being an engineer
You're stupid for not using the apostrophe in you're.Originally posted by Cletus View Postbox 1" od 4 feet cut in half
box 1" id 1 foot
bam win
a shock absorber that can efficiently control and dampen somethin in the neighborhood of 5 pounds?Originally posted by Cletus View Post
im not sure im confident an actual shock would remove vibes that im worried about either...itd take out jarring stuff...but tight vibrations can still be transmitted through the shock unless it was incredibly sensitive...no?
i illustrated my thoughts....direct side view, obviously 4 springs, 1 per corner on a rectangle plate
So where does the camera mounting plate go?Originally posted by Cletus View Postbox 1" od 4 feet cut in half
box 1" id 1 foot
bam win
