He probably ate so many crayons as a kid that the smell doesn't even phase him anymore.
2000 Jetta HELP!
Technically, yes but my rims aren't wider than the tire. Instead of making shitty snide remarks, you can answer my question or is that beyond the scope of your understanding.
I'll ask it again just in case you did see the question the first time: Why do people use rims that are much wider than the tire? You answer "to fit the rims at the desired height." makes no sense to me, so please elaborate.sigpic
Originally posted by Buffalo Phil View PostI'll ask it again just in case you did see the question the first time: Why do people use rims that are much wider than the tire? You answer "to fit the rims at the desired height." makes no sense to me, so please elaborate.
Reason for stretching tires now is to get the angle of the tire side wall about the same as the inside of fender (which has been rolled flat back up to its self).
At least that is how I understand it. I have never had or wanted stretched tires.
Originally posted by Lumbergh View PostFunny I have towed cars before, easily 2-3 times as many jeeps towed off the road vs. VW.VWs also have terrible electronics. I agree jeeps do break down, so do all vehicles, but if my tranny ever breaks I go to a junkyard and get one from a crashed jeep for 200 bucks and swap it in. German engineering is a huge FAIL, thats why they lost the war.
-Josh
Originally posted by Lumbergh View PostOriginally: "The whole thing started in germany/belgium, local laws required that the tire tread be within the fender line. well that doesnt allow one to run wider or lower offset wheels, so they put narrower tires on the wheel to maintain legality"
At least that is how I understand it. I have never had or wanted stretched tires.-Josh
Originally posted by jeepkid03 View PostI'm just wondering how they mount those? Those tires sound like a bitch to mount on the rims. I can imagine you wouldn't be able to use a regular tire machine if you have to stretch them??
