As many of you know, the 8.8 is a common rear axle swap for Jeep because of the ability to retain the 5 on 4.5 bolt pattern. What I realized, is that there isn't a whole lot of options to upgrade the front axle(D44/etc.), unless you run custom shafts in the 8.8.
Not a big deal, but it got me to thinking, what about an 8.8 front axle? I remember reading about it somewhere, but with a bunch of searching I came up with nothing.
I don't know a whole lot about this subject, so how exactly would you go about doing this? Is it even possible?
The main problem I figured you would run into, is how exactly would you set up the housing to be configured for a front axle? I was under the impression you would flip the housing to high pinion, and run reverse cut gears. Now, I'm pretty sure there isn't a company that offers reverse cut 8.8 gears. Also, would flipping the housing create oiling issues?
The other issue I came up with, would be the outers. I think I remember hearing that you can get aftermarket 8.8 rear shafts drilled for 5 on 4.5 and 5 on 5 bolt patterns off the shelf. I also think, that JK's use 5 on 5 bolt patterns. So, would it be possible to use complete JK outer assembalies and have custom inner shafts made?
Feel free to tell me I'm an idiot, it was just a thought that sprouted in my head.
