One ton steering problems.....
    hahaha yeah sowwy for my shitty first description guys
    JeepJuggalo DO NOT HIT YOU COVER WITH A HAMMER, BAD IDEA
      OHHH
      i thought you were talkin about hammering on a full cover lol
      I'm not that stupid Sorry about that
        not so concerned about diff cover as i am the track bar axle bracket i already reamed the bottom of the knuckles so i am stuck running the utk now i guess. i will try to take a pic but even if i bent the tube somewhat what happens if i need an alignment and tat tube needs to be turned..lol won't it be bent in then causing more clearence issues? and tha trackbar bracket is over to the pass side so i'd have to bend it what seems to be quite a bit. i welded a 3/16 plate over the stock axle bracket for some reinforcement (on the outside and top) and even without the bolt in it hits the plate at 3/4 turn. the tube is cut nothing welded in yet figured i'd test fit it and this happened. i cut tube so that only about 4 or 5 threads are out each side. should i cut it a little shorter or is it better the closer they are ?
        88 manche-96 4.0 OBDII 5in 35's-new bumper..parked
        ..............back under construction...
        96 2door donor....
        94 yj 4.0 5 sp .... dd only mods no track or sway bars
          just called complete offroad, they said to bend the tube..lol or to swap the eyelet tie rod to run towards the box rather than to the pass knuckle which will basically be like the factory setup, which i am trying to avoid so my angles are better i dunno
          96 2door donor....
            FWIW you should still be able to switch to OTK even though you reamed from the bottom already.
            My D44 was from an F-250 that ran 1-ton TRE's UTK, and I reamed from the top and called it good.
              yeah sweet reamed from top went mint ......trimmed the spring plates and shit right up to the coil put in in otk turned the wheel and BAMO right int the spring still about a quarter inch to go berore i hit steering stops ...lol this kit does not work on late model dana 30's and because of me theres now a note on the newly redesigned web page...lol
              96 2door donor....
