gears
    probably a 3:07... a set of 3:55s is even noticeable
      will have a dana 30 with 3.55s no shafts coming out soon
        I'll have a d30 with 4.10s coming out soon
          shafts mine
            Originally posted by Bigbike View Post
            shafts mine
            You wants?
              You wants?
              just the shafts not the whole thing.
                get a 8.8 with 4:10's and a front axle from a 4-banger TJ (4:10's). BAM factory axle swap.
                and 4:10's with 33's is not bad at all
                im vewwy intewested in vissss..... (chinese face on)
                i do not plan on going any bigger than 33s and i would invest in ring and pinions with lockers but why bother on an 8.25 27 spline and d30? i mean i have a kid and specifically for that reason i cant go crazy with time and money, so i figure an 8.8 and maybe even a d30 rebuild/ restrengthen will be a doable if i plan on locking the 8.8 in the future no?
                  the 30 is plenty strong enough for 33s, i have 35s on the dana 30 right now. You can get away with 33s and a locker on the 8.25 27 spline as long as you are not thrashing it.
                  The 30 can be upgraded with the 297 shafts
                    If you need an 8.25 (29 spline) with 3.55s mine should be out by the meet and greet.
                      you can get honda passport dana 44's and the isuzu equivalent with 4.56 stock if it has a 4 banger and disc brakes
                        x2 your axles would be fine for 33s, an i would do 4.56s if it was me
                        97 zj- frankenstein 3.5", 35 stt's.
                        92 240sx- coilovers,full adj arms bla bla bla. 50trim t3/t04 soon
                        xj- need one
