gears
  • gears
    what gears are recommended/ better than stock for 33" tires?
    been covered a million times 4.56 will be pretty good
      i figured it has i was just checking up on it after reading rediculous debates on cherokeeforum. thanks rj you saved my life
      now can i find these factory in a 44 or 60 or 8.8?
        very very uncommonly found in XJs- 2.5L, but im pretty sure theyre only in turdy fives. as to the 8.8, i think you can get 4.11.
          none of them came with 4.56 stock iirc most came with 4.10s and lower
          could stay with the 3.55s you probably got and swap in a 8.25 or an xj 44 if you can find it
          http://pirate4x4.com/forum/showthread.php?t=820400
          i have the ubolts and perches for the 8.8 for sale if you get it
            4.56:1, automatic transmission, I4, offroad or tow package.
              and what did that come in?
                XJ
                  never seen that before only 4.10s as the deepest
                    not positive, assuming 35, c clip which would make it 1990 or later. its at least an option if you dont want to swap axles yet.
                      i have seen the 4.56 tag on a stock xj axle...but its insanely insanely rare..not worth thinkin about for a swap for that reason IMO
                        get a 8.8 with 4:10's and a front axle from a 4-banger TJ (4:10's). BAM factory axle swap.
                        and 4:10's with 33's is not bad at all
                          I have an 8 1/4 in it now. I am looking to do a swap in the future so I figured I'd ask in advance. My Jeep is a standard so the gears aren't even 3.55 are they?
                            probably 3.07's
                              it maybe 3.55 it maybe 3.07 youll have to read your axle tag to know
