school me on towing
  • school me on towing
    i'm looking at 99-03 2wd short bed/reg cab silverado's with either the 4.8 or 5.3 for towing purposes. the plan is to tow vehicles to my storage lot with it mostly suvs, some cars, maybe a full size truck sometimes. is the short wheelbase/2wd gonna be able to handle it?
    tow truck maybe?
      hah dont need a tow truck. only will be used maybe 4 or 5 times a month.
        i dont see why not, the shortbed shouldnt have a huge effect on the minimal towing you plan to do with it
          I have a 99 sierra single cab long bed 2wd 2500 with a 5.7 that I tow with on occasion. Tows great. I'd go with a 5.3 but that's just my opinion.
            buy a 2500
            you can get them for cheep
            the short wb/2wd will have a lower tow rating then an extended cab
              buy a 2500
              times two
              Most of the time when I do landscaping I use the 3500 6.6 turbo diesel, which, you don't know anything attached to you, but sometimes I have to use the 2500, and once I used the 1500. all three towing the same trailer, def diff between 25 and 15.
                i can't believe how expensive these trucks are. 11 year old 2wd nothing in it work truck 1500s are still goin for 4 grand . . . i might have to go older. i only wanted to spend 2500
                  yikes...
                  http://newlondon.craigslist.org/cto/1575779711.html
                  http://hartford.craigslist.org/cto/1582579150.html
                    for the record my sierra has 207k on it and still runs great. I wouldn't let high miles (between 160-200k) scare you. at least with a 5.7
                      i'm not worried about miles. those lsx motors will run forever
                        that first one is alot more than i want but would be nice
                          I prefer to Tow with a Diesel-Cummins or 7.3L PSD!
                          Do some research and see what the Tow Capacities of the vehicle you are thinking about purchasing have.
                          Proper planning prevents poor performance
                          HOONIGAN FOR LIFE
                          OLD 4X4'S NEVER DIE!!!!!
                            if you want a 1500 chevy do not get the 4.8 unless it's a newer model the older 4.8's sucked, the 5.3 is a great motor
                              Power is the only issue I see, those motors are both high revers!
                              My last tow rig was a caprice with a 5.7 which has to be shorter than a shortbed truck still and my current is a grand cherokee with 4.7 which is even shorter than the caprice I believe. Some call me crazy but I think they both tow great! Def get at least the 5.3. Chevy has a hard time building motors with low end torque!
